查看: 5139|回复: 6
[招聘] 代发:O2micro上海office职位:Digital IC Design Engineer-SH807
发表于 2011-3-22 13:33:28 | 显示全部楼层 |阅读模式
代发消息,有兴趣请联系:nellie.zhang@o2micro.com
JD如下:
Job Responsibilities:
1.             Working on digital IC design/verification;
2.             Responsible for RTL design & simulation, pre-/post-layout simulation, FPGA verification, logic synthesis, static timing analysis, test pattern generation for ATE;
3.             Cooperating with analog group, interfacing to supporting groups such as software, layout, test, and product engineering.
Job Requirements:
1.             BS Degree or above in EE or equivalent;
2.             3+ years working experience in ASIC design;
3.             Familiar with ASIC design flow and IC design tools such as VCS, Verilog-XL, ModelSim, Design Compiler, Prime Time etc.;
4.             Must be proficient in Verilog/VHDL, and digital low power design;
5.             DFT technique and synthesis, test vector generation and fault coverage simulation;
6.             Experience on FPGA verification;
7.             Knowledge of communication interfaces such as I2C, SMBUS, SPI, LIN bus, CAN bus is a plus;
8.             Familiarity of 8/16 bit microcontroller design is preferred;
9.             Experience of mixed-signal design is preferred;
10.           Good oral and written English communication skills;
11.           Creative, self-motivated, responsible, good team work spirit.
发表于 2011-3-23 00:23:14 | 显示全部楼层
凹凸不是在成都和武汉吗?还是?
发表于 2011-3-23 09:31:08 | 显示全部楼层
想再详细了解下
发表于 2011-3-23 14:15:05 | 显示全部楼层
上海也有的,而且很强大!嘎嘎
 楼主| 发表于 2011-3-23 17:22:35 | 显示全部楼层
回复 2# TomPaul
    嗯,这个职位是上海office的,地址在张江大厦。
 楼主| 发表于 2011-3-23 17:25:17 | 显示全部楼层
回复 3# IChina
    想了解什么情况?我一定知无不言。
发表于 2011-3-24 01:45:27 | 显示全部楼层
sixty sec is more
GMT+8, 2025-12-22 20:48 , Processed in 0.018812 second(s), 4 queries , Gzip On, Redis On.
