查看: 13652|回复: 9
[资料] Circuits and Systems II: Express Briefs 2011 Jan-Mar
发表于 2011-3-18 12:18:37 | 显示全部楼层 |阅读模式
Circuits and Systems的Express Briefs中都是最新的文章,从收录到发表大约只有三个月的时间。
文章篇幅也限于5页,给作者简单介绍自己最新的研究成果,而不是详细的介绍。
对于希望了解业界最新动态,浏览一些文章的读者,特别合适。
以下是2011 Jan Feb Mar三月的目录,正好一个包。
A CMOS 8-Bit 1.6-GS/s DAC With Digital Random Return-to-Zero
Wei-Hsin Tseng  Jieh-Tsorng Wu  Yung-Cheng Chu
Page(s): 1 - 5
Calculation of Cycle Lengths in Higher Order Error Feedback Modulators With Constant Inputs
Fitzgibbon, B.  Kennedy, M.P.
Page(s): 6 - 10
Power-Constrained Third-Order Active Notch Filter Applied in IR-LNA for UWB Standards
Jui-Yi Lin  Hwann-Kaeo Chiou
Page(s): 11 - 15
Feedforward Interference Cancellation Architecture for Short-Range Wireless Communication
Hori, S.  Murmann, B.
Page(s): 16 - 20
Fully Differential Current-Mode CMOS Triode Translinear Multiplier
Miguel, J.M.A.  De La Cruz Blas, C.A.  Lopez-Martin, A.J.
Page(s): 21 - 25
Low-Noise CMOS TGC Amplifier With Adaptive Gain Control for Ultrasound Imaging Receivers
Yikai Wang  Koen, M.  Dongsheng Ma
Page(s): 26 - 30
Current-Mode Analog Adaptive Mechanism for Ultra-Low-Power Neural Networks
Dlugosz, R.  Talaska, T.  Pedrycz, W.
Page(s): 31 - 35
A Dual-Layer Method for Transient and Permanent Error Co-Management in NoC Links
Qiaoyan Yu  Ampadu, P.
Page(s): 36 - 40
Isolated Two-Transistor Zeta Converter With Reduced Transistor Voltage Stress
Murthy-Bellur, D.  Kazimierczuk, M.K.
Page(s): 41 - 45
Farrow-Structure-Based Reconfigurable Bandpass Linear-Phase FIR Filters for Integer Sampling Rate Conversion
Johansson, H.
Page(s): 46 - 50
A Sequential Minimization Procedure for Minimax Design of IIR Filters Based on Second-Order Factor Updates
Xiaoping Lai  Zhiping Lin  Hon Keung Kwan
Page(s): 51 - 55
A Low-Cost MMSE-SIC Detector for the MIMO System: Algorithm and Hardware Implementation
Tsung-Hsien Liu  Jin-Yi Jiang  Yuan-Sun Chu
Page(s): 56 - 61
A 0.5/0.8-V 9-GHz Frequency Synthesizer With Doubling Generation in 0.13- $muhbox{m}$ CMOS
Ching-Yuan Yang  Chih-Hsiang Chang  Jun-Hong Weng  Hsin-Ming Wu
Page(s): 65 - 69
A 1-GHz Digital PLL With a 3-ps Resolution Floating-Point-Number TDC in a 0.18- $muhbox{m}$ CMOS
Young-Hun Seo  Seon-Kyoo Lee  Jae-Yoon Sim
Page(s): 70 - 74
A Laser-Trimmed Rail-to-Rail Precision CMOS Operational Amplifier
Singh, R.  Audet, Y.  Gagnon, Y.  Savaria, Y.  Boulais, E.  Meunier, M.
Page(s): 75 - 79
A Low-Power Energy-Harvesting Logarithmic CMOS Image Sensor With Reconfigurable Resolution Using Two-Level Quantization Scheme
Law, M.K.  Bermak, A.  Shi, C.
Page(s): 80 - 84
A Wide-Dynamic-Range CMOS Image Sensor With Gating for Night Vision Systems
Spivak, A.  Belenky, A.  Fish, A.  Yadid-Pecht, O.
Page(s): 85 - 89
A Delta–Sigma Interface Circuit for Capacitive Sensors With an Automatically Calibrated Zero Point
Dong-Yong Shin  Hyunjoong Lee  Suhwan Kim
Page(s): 90 - 94
Power-Saving 4 $times$ 4 Lattice-Reduction Processor for MIMO Detection With Redundancy Checking
Chun-Fu Liao  Yuan-Hao Huang
Page(s): 95 - 99
Secure Variable Data Rate Transmission
Cohen, A.E.  Parhi, K.K.
Page(s): 100 - 104
An Autocalibrated All-Digital Temperature Sensor for On-Chip Thermal Monitoring
Ching-Che Chung  Cheng-Ruei Yang
Page(s): 105 - 109
A Modified Chaos-Based Joint Compression and Encryption Scheme
Jianyong Chen  Junwei Zhou  Kwok-Wo Wong
Page(s): 110 - 114
Design of Multiplierless Decimation Filters Using an Extended Search of Cyclotomic Polynomials
Laddomada, M.  Troncoso, D.E.  Jovanovic Dolecek, G.
Page(s): 115 - 119
A New Transform-Domain Regularized Recursive Least M-Estimate Algorithm for a Robust Linear Estimation
Chan, S.C.  Zhang, Z.G.  Chu, Y.J.
Page(s): 120 - 124
RF Front-End Concept and Implementation for Direct Sampling of Multiband Signals
Munoz-Ferreras, J.-M.  Gomez-Garcia, R.  Perez-Martinez, F.
Page(s): 129 - 133
A Dual-Band GNSS RF Front End With a Pseudo-Differential LNA
Wu, J.  Jiang, P.  Chen, D.  Zhou, J.
Page(s): 134 - 138
A Noise Filtering Technique for Fractional-  Frequency Synthesizers
Hung, C.-C.  Liu, S.-I.
Page(s): 139 - 143
High-Speed Low-Power True Single-Phase Clock Dual-Modulus Prescalers
Chen, W.-H.  Jung, B.
Page(s): 144 - 148
Built-in Self-Calibration Circuit for Monotonic Digitally Controlled Oscillator Design in 65-nm CMOS Technology
Chung, C.-C.  Ko, C.-Y.  Shen, S.-E.
Page(s): 149 - 153
Phase Noise Simulation in Analog Mixed Signal Circuits: An Application to Pulse Energy Oscillators
Bizzarri, F.  Brambilla, A.  Gajani, G. S.
Page(s): 154 - 158
Low-Power and Widely Tunable Linearized Biquadratic Low-Pass Transconductor-C Filter
Tajalli, A.  Leblebici, Y.
Page(s): 159 - 163
12-b Enhanced Input Range On-Chip Quasi-Digital Converter With Temperature Compensation
Azcona, C.  Calvo, B.  Medrano, N.  Bayo, A.  Celma, S.
Page(s): 164 - 168
A Low-Cost and Low-Power Time-to-Digital Converter Using Triple-Slope Time Stretching
Kim, M.  Lee, H.  Woo, J.-K.  Xing, N.  Kim, M.-O.  Kim, S.
Page(s): 169 - 173
Dynamic Bias-Current Boosting Technique for Ultralow-Power Low-Dropout Regulator in Biomedical Applications
Ho, M.  Leung, K. N.
Page(s): 174 - 178
New Approach to Realize Fractional Power in  -Domain at Low Frequency
Visweswaran, G. S.  Varshney, P.  Gupta, M.
Page(s): 179 - 183
PID-Based Bit Allocation Strategy for H.264/AVC Rate Control
Zhou, Y.  Sun, Y.  Feng, Z.  Sun, S.
Page(s): 184 - 188
TCASII_2011_01_03.rar
14.09 MB, 下载次数: 119 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2011-3-18 21:42:31 | 显示全部楼层
niu.好贴要顶
发表于 2011-3-25 18:19:17 | 显示全部楼层
kan kan, thanks...It's very nice for me!!!
发表于 2011-3-28 08:55:47 | 显示全部楼层
正好需要,下来看看
发表于 2011-3-28 09:03:29 | 显示全部楼层
ddddddddddddddddddddddd
发表于 2011-4-22 09:42:52 | 显示全部楼层
thanks for sharing
发表于 2011-4-22 12:25:14 | 显示全部楼层
发表于 2012-7-20 12:54:59 | 显示全部楼层
回复 1# sun-moon
    xiexie,很不错!!!
发表于 2015-7-13 10:43:33 | 显示全部楼层
正在看一篇文章,很不错
发表于 2017-3-26 12:03:57 | 显示全部楼层
haodongxi !!!
GMT+8, 2025-12-9 15:39 , Processed in 0.027640 second(s), 6 queries , Gzip On, Redis On.
