查看: 2697|回复: 3
[资料] 3G PA datasheet
发表于 2011-3-15 10:10:51 | 显示全部楼层 |阅读模式
PRODUCT DESCRIPTION
BN7301 is a monolithically integrated power amplifier Module. The PA is manufactured on Heterojunction Bipolar Transistor(HBT) process and has been designed for WCDMA/TD-SCDMA handheld equipment and other wireless applications in the 1880MHz ~ 2025MHz band. The package of this chip is 4mm×4 mm×1.1mm LGA with 10 pins. The input and output are internally matched to 50Ω to simplify the system design.
FEATURES
1.Advanced HBT process
2.27dBm linear output power
3.Low quiescent current
4.Good linearity
5.High efficiency
6.3.0~5.0 V Power supply voltage
BN7301datasheetv0.1(1).pdf (91.96 KB , 下载次数: 17 )
头像被屏蔽
发表于 2011-4-7 16:16:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-5-8 15:41:14 | 显示全部楼层
good communityhere !
发表于 2011-8-6 22:14:24 | 显示全部楼层
Thanks.
GMT+8, 2025-12-28 09:56 , Processed in 0.016845 second(s), 8 queries , Gzip On, Redis On.
