查看: 34500|回复: 89
[资料] Keil C51 V9.03下载地址及Crack
发表于 2011-3-4 16:36:24 | 显示全部楼层 |阅读模式
Keil C51 V9.03出来啦!
这个是我刚刚通过注册获得的Keil C51 V9.03下载地址。
http://www.keil.com/fid/ud3hvvwdb3mj1wxzd611dswas9xdwdgwwg1yd1/files/eval/c51v903.exe
也可以通过下面的地址来获得
http://www.mcu123.com/news/Soft/embsof/uc/201102/532.html
至于Crack应该还是可以使用原来的,附件中 KEIL_Lic.rar (16.3 KB , 下载次数: 450 ) 即是!
遗憾的是:此版本程序依然没有解决0xFD的问题,可以使用附件中的“C51V903_test_0xFD.rar” C51V903_test_0xFD.rar (1.47 MB , 下载次数: 690 ) 来做验证和修复。
还发现了一个小问题:过去的版本都可以使用WinRAR来进行解压,这一版本不可以了。(过去都是用WinRAR将安装程序打开,然后将0xFD问题的修复程序文件A51.exe,C51.exe直接覆盖掉源程序,现在这一方法无法实现了!)
更新了部分内容如下:C51 Version 9.03 Release
  • [Cx51 Compiler]
    • Improved: Evatronix R8051XC2 core now uses the MDU for signed long divisions.
    • Corrected: With OPTIMIZE(8, SIZE) or higher optimization levels there is a potential problem with common code generation of long/float store operations that store constants with different memory types. Example:
      int flag;long xdata l;long *pl;void main (void)  {  if (flag)  {   l = 0; flag = 1; }   // store with identical constant value but different space   else       { *pl = 0; flag = 1; }   // may create incorrect common blocks }
  • [LX51 Linker/Locater]
    • Improved: When using Linker Code Packing the gaps in the BANKAREA are not optimized.
    • Corrected: Potential SEGMENT OVERLAPS when using Linker Code Packing on a banking application.
  • [New Supported Devices]
    • Atmel AT80C51RD2, AT89LP213, AT89LP216, AT89LP52, and AT89LP6440 devices.
    • Infineon XC878LM-13F, XC878CLM-13F, XC878LM-16F, XC878CLM-16F, XC874-13F, XC874LM-13F, XC874CM-13F XC874CLM-13F, XC874-16F, XC874LM-16F, XC874CM-16F, XC874CLM-16F, and XC836MT-1F devices.
    • NXP P87C51FA, P87C51FB, P89CV51RB2, P89CV51RC2, P89CV51RD2, P89LPC779, and P87V660X2 devices.
    • Silabs C8051F348, C8051F349, C8051T606, C8051T630, C8051T631, C8051T632, C8051T633, C8051T634, C8051T635, C8051F540, C8051F541, C8051F542, C8051F543, C8051F544, C8051F545, C8051F546, C8051F547, C8051F550, C8051F551, C8051F552, C8051F553, C8051F554, C8051F555, C8051F556, C8051F557, C8051F560, C8051F561, C8051F562, C8051F563, C8051F564, C8051F565, C8051F566, C8051F567, C8051F568, C8051F569, C8051F570, C8051F571, C8051F572, C8051F573, C8051F574, C8051F575, C8051F34A, C8051F34B, C8051F34C, C8051F34D, C8051F716, C8051F717, C8051F980, C8051F981, C8051F982, C8051F983, C8051F985, C8051F986, C8051F987, C8051F988, C8051F989, C8051F990, C8051F991, C8051F996, C8051F997, C8051F800, C8051F801, C8051F802, C8051F803, C8051F804, C8051F805, C8051F806, C8051F807, C8051F808, C8051F809, C8051F810, C8051F811, C8051F812, C8051F813, C8051F814, C8051F815, C8051F816, C8051F817, C8051F818, C8051F819, C8051F820, C8051F821, C8051F822, C8051F823, C8051F824, C8051F825, C8051F826, C8051F827, C8051F828, C8051F829, C8051F830, C8051F831, C8051F832, C8051F833, C8051F834, C8051F835, C8051F901, C8051F902, C8051F911, C8051F912, Si1000, Si1001, Si1002, Si1003, Si1004, Si1005, Si1010, Si1011, Si1012, Si1013, Si1014, Si1015, C8051F520A, C8051F521A, C8051F523A, C8051F524A, C8051F526A, C8051F527A, C8051F530A, C8051F531A, C8051F533A, C8051F534A, C8051F536A, and C8051F537A devices.
    • Teridian Semiconductors 78M6612, 78M6618, and 71M6543 devices.
    • Texas Instruments CC2530F32, CC2530F64, CC2530F128, CC2530F256, CC2531F128, CC2531F256, CC2533F32, CC2533F64, CC2533F96, CC2540F128, and CC2540F256 devices.
  • [μVision]
    • This C51 release comes with μVision V4.14.16.
另:喜欢追新的网友,可以移步到下面的网址:keil C51 V906
http://bbs.eetop.cn/thread-322426-1-1.html
发表于 2011-3-5 11:14:16 | 显示全部楼层
非常感谢。。
发表于 2011-3-6 11:01:42 | 显示全部楼层
不错a
发表于 2011-3-6 18:48:33 | 显示全部楼层
see see
发表于 2011-3-11 20:08:14 | 显示全部楼层
真是實用
謝謝micdot 大大提供
還有注冊程式防毒軟體真的會擋
要先關一下
3Q
发表于 2011-3-15 07:52:59 | 显示全部楼层
真是實用
发表于 2011-3-19 08:59:14 | 显示全部楼层
这个版本可以和Protues联调吗?
发表于 2011-3-23 20:16:10 | 显示全部楼层
真是實用
发表于 2011-3-31 17:49:34 | 显示全部楼层
哇 版本号都这么高了
 楼主| 发表于 2011-4-1 00:10:20 | 显示全部楼层
回复 7# bobgeng
    这个版本的不知道是否可以,但是我想试试,正在学习中……
GMT+8, 2025-9-19 05:41 , Processed in 0.022158 second(s), 8 queries , Gzip On, Redis On.
