查看: 3402|回复: 9
[求助] 请教sigma delta AD的参考电平电路怎么做
发表于 2011-2-22 09:50:38 | 显示全部楼层 |阅读模式
sdm的Fs=1M,OSR=1024,参考电平要怎么考虑啊?有没有什么好的资料可以参考,谢谢
发表于 2011-2-22 11:28:20 | 显示全部楼层
Fs=1M,OSR=1024, 这么牛??
做什么用啊? OSR=1024 ?????????????????????
 楼主| 发表于 2011-2-22 16:11:59 | 显示全部楼层
sdm本身不是我做的,我就负责做两个参考电平
做什么用,这个不方便说啊
发表于 2011-2-26 21:46:35 | 显示全部楼层
最简单的用电源电压,一切ok
发表于 2011-2-27 20:18:04 | 显示全部楼层
This is a tricky question. If the SDM has a moderate dynamic range, the Vref can be generated on chip. Using a bandgap reference to drive a fully-differential amplifier will give Vhigh and Vlow, and therefore the Vref. The design of the fully-differential amplifier with minimum power requires a bit of knowledge. There is a document from Analog Device talking about this.
If your SDM has a very high SNDR, say >100dB, then Vref is good to be off-chip. Just my two cents.
发表于 2011-4-28 22:24:48 | 显示全部楼层
楼主找到正确答案了吗?我也正有这个问题要问呢。
发表于 2011-4-28 22:27:29 | 显示全部楼层
发表于 2011-4-28 23:04:34 | 显示全部楼层
不懂!
发表于 2011-4-29 09:31:07 | 显示全部楼层
输入信号500Hz带宽
通常bandgap做出来的Vref低频噪声抑制比较好,应该不难做
发表于 2011-4-29 11:08:18 | 显示全部楼层
BG + fully-differential OPA is ok.
GMT+8, 2025-12-29 16:48 , Processed in 0.178228 second(s), 5 queries , Gzip On, Redis On.
