查看: 6440|回复: 14
[资料] MOST--The automotive multimedia network
发表于 2011-2-9 14:56:27 | 显示全部楼层 |阅读模式
        9
Contents
Part 1
MOST Standard
1    MOST Cooperation  .................................................................   19
      1.1      Motivation and History  ..................................................  19
      1.2      Fast Standardization .....................................................  21
      1.3      Structure and Specification Work  .....................................     22
       1.3.1   The Steering Committee   ................................................   22
       1.3.2   The Administrator ........................................................  23
       1.3.3   The Technical Coordination Group  ....................................      23
       1.3.4   The Working Groups  .....................................................   24
       1.3.5   The Technical Coordinator  ..............................................   24
      1.4      The Compliance Verification Program  ................................       25
2    Network Architectures in Automotive Applications  .........................           26
      2.1      Automotive Applications ................................................    27
      2.2      The Function-Oriented Approach ......................................       27
      2.3      Communication Requirements       ........................................   30
      2.4      Standardization and Classification  ...................................     32
       2.4.1   Standardization ........................................................... 32
       2.4.2   Communication Systems for Closed Loop Control Functions ....                33
       2.4.3   Communication Systems for Open Loop Control Functions ......                33
       2.4.4   Infotainment Communication Systems         ..............................   34
       2.4.5   Summary  ................................................................... 35
      2.5      Vehicle Network Architectures  .........................................    35
       2.5.1   Central Gateway ..........................................................  36
3    Survey of the System Architecture     .............................................   37
      3.1      MOST Layer Model  .......................................................   37
      3.2      Application Framework ..................................................    38
      3.3      Network-Services  ......................................................... 41
      3.4      MOST Data Link Layer ....................................................   42
       3.4.1   MOST Frame ...............................................................  42
       3.4.2   Timing Master, Timing Slave   ...........................................   43
      3.5      Physical Layer  ............................................................. 44
       3.5.1   Optical Physical Layer  ...................................................  45
       3.5.2   Electrical Physical Layer .................................................  46
      3.6      MOST Device ...............................................................  46
      3.7      Network Management  ...................................................      47
       3.7.1   NetBlock .................................................................... 47
       3.7.2   PowerMaster ..............................................................   48
       3.7.3   Network Master; Network Slave  .......................................       48
       3.7.4   ConnectionMaster ........................................................    49
      3.8      Transmission of Multimedia Data  .....................................       49
4    Application-Framework    ...........................................................   50
      4.1      Device Model ..............................................................  50
      4.2      Application Protocol  .....................................................  52
       4.2.1   Data Format ................................................................ 52
       4.2.2   Dynamic Behavior  ........................................................   59
      4.3      MOST Function Blocks ...................................................     65
       4.3.1   Structure of a Function Block   ..........................................   66
       4.3.2   Function Classes ..........................................................  67
       4.3.3   Function Interfaces .......................................................  69
       4.3.4   System FBlocks ...........................................................   69
       4.3.5   Administration of Synchronous Channels  ...........................          73
      4.4      Standardized FBlocks for Applications       ..............................   76
       4.4.1   Function Catalog ..........................................................  76
       4.4.2   Jointly used Functions (GeneralFBlock)  ..............................       78
       4.4.3   Application Interfaces  ...................................................  78
       4.4.4   Example of Use (AuxIn)   .................................................   81
5     MOST Protocols .....................................................................  85
      5.1      MOST25 Frame ............................................................    85
       5.1.1   Preamble  ................................................................... 86
       5.1.2   Boundary Descriptor  .....................................................   86
       5.1.3   Frame Control .............................................................  87
      5.2      Synchronous Area  ........................................................   87
      5.3      Asynchronous Area   ......................................................   89
      5.4      Control Channel ...........................................................  92
      5.5      Addressing ................................................................. 96
      5.6      MOST50 Frame ............................................................    99
      5.7      Higher Protocols  ......................................................... 100
       5.7.1   MOST High Protocol (MHP)       ............................................ 100
       5.7.2   MAMAC  .................................................................... 104
        Contents           11
6     Physical Layer ...................................................................... 105
       6.1     Introduction    .............................................................. 105
       6.2     POF Plastic Optical Fibers .............................................. 106
       6.2.1   Basic Principles  .......................................................... 106
       6.2.2   Polymer Fibers – Properties and Advantages ...................... 108
       6.3     Contacting of PMMA Fibers ............................................ 111
       6.4     Opto-Electronic Transceivers  .......................................... 113
       6.4.1   LED Transmitter Units ................................................... 113
       6.4.2   PIN Photodiodes ......................................................... 115
       6.4.3   Transceiver Housing and Connectors ................................ 115
       6.5     System Considerations for the MOST Physical Layer  ............. 119
       6.5.1   Basic Principles of Optical and Electrical Parameters ............ 119
       6.5.2   Optical and Electrical Requirements           ................................ 125
       6.5.3   Power Budget      ............................................................ 128
       6.5.4   Timing Requirements  ................................................... 130
       6.6     Further Developments of the Physical Layer  ....................... 133
       6.6.1   MOST Systems with higher Data Rates .............................. 133
       6.6.2   Alternative Transmission Media  ...................................... 134
7     Network Management ............................................................ 140
       7.1     Wake-up  ................................................................... 140
       7.2     System Initialization  .................................................... 142
       7.2.1   System Query      ............................................................ 142
       7.2.2   Central Registry  .......................................................... 143
       7.2.3   Network System Status ................................................. 143
       7.2.4   Dynamic Addressing  .................................................... 145
       7.2.5   Examples of System Starts         ............................................ 146
       7.3     Notification  ............................................................... 147
       7.4     Power-Down  .............................................................. 149
       7.5     Error Management        ...................................................... 150
       7.5.1   Optical Events ............................................................ 150
       7.5.2   Over-Temperature       ....................................................... 151
       7.5.3   Undervoltage  ............................................................. 152
8     MOST Interface Controller  ....................................................... 153
       8.1     The Hardware Structure of a MOST Node  ........................... 153
       8.2     The Concept of the MOST Network Interface Controllers                 ........ 154
       8.2.1   INIC  ......................................................................... 154
       8.2.2   NIC .......................................................................... 155
       8.3     Intelligent Network Interface Controller (INIC)  ..................... 156
       8.3.1   Available Interfaces  ..................................................... 156
12       Contents
        8.3.2   Ports, Sockets and Connections  .................................... 156
        8.3.3   Communication with the INIC on the part of the EHC             .......... 158
        8.3.4   The Role of the INIC with regard to the MOST Network ......... 160
        8.3.5   Communication Paths in the INIC        .................................. 161
        8.3.6   MediaLB, the Synchronous Multi-Purpose Interface ............ 162
        8.3.7   The Control Port  ........................................................ 165
        8.3.8   The Streaming Port  .................................................... 165
        8.3.9   Interfaces for Control Data in INICs     ................................ 166
       8.3.10   Interfaces for Streaming Data in INICs ............................. 166
       8.3.11   Interfaces for Packet Data in INICs     ................................. 166
       8.3.12   Examples of INIC components        ...................................... 166
       8.4      Network Interface Controller (NIC) .................................. 166
        8.4.1   Available Interfaces  ................................................... 167
        8.4.2   Serial Operation  ....................................................... 168
        8.4.3   Parallel Operation of CP and SP      .................................... 168
        8.4.4   Possible Configurations (Serial/Parallel)       ......................... 169
        8.4.5   The Basic Configuration of a NIC      ................................... 170
        8.4.6   Interfaces for Control Data in NICs     ................................. 170
        8.4.7   Interfaces for Streaming Data in NICs       ............................. 170
        8.4.8   Interfaces for Packet Data in NICs  .................................. 171
        8.4.9   Secondary Node    ....................................................... 171
9     Network Service .................................................................. 175
       9.1      Overview ................................................................. 175
       9.2      MOST NetServices  ..................................................... 176
        9.2.1   Models of MOST NetServices ........................................ 177
       9.3      Modules of the MOST NetServices  ................................. 177
        9.3.1   Layer I Version 1.x ..................................................... 177
        9.3.2   Layer I Version 2.x ..................................................... 180
        9.3.3   Layer II Versions 1.x and 2.x ......................................... 181
       9.4      Integration of the MOST NetServices onto the Target Platform              186
        9.4.1   Callback Functions   .................................................... 186
        9.4.2   Main Loop Architecture ............................................... 187
        9.4.3   Multitasking Architectures  ........................................... 188
        9.4.4   System Management Module  ....................................... 189
10   MOST System Design – V-Model XT and MSC ............................... 190
     10.1      The V-Model XT1  ......................................................... 190
     10.2      System Specification   ................................................... 195
     10.3      System Design  ........................................................... 197
     10.4      Detail Design of the System  ........................................... 198
        Contents          13
       10.5    Realization of the System Elements  ................................. 199
       10.6    The Description Language Message Sequence Chart (MSC)                   ... 199
      10.6.2   High-Level MSC  .......................................................... 204
11    Testing MOST-based Infotainment Systems ................................. 205
       11.1    Challenges in Testing MOST Systems ................................ 205
       11.2    Overview of the OEM Test Activities       ................................. 206
       11.3    The Test Process  ......................................................... 207
       11.4    Component Tests  ........................................................ 208
       11.5    Integration Tests  ......................................................... 211
       11.6    System Tests .............................................................. 212
       11.7    Test Tools .................................................................. 213
12    Compliance Tests .................................................................. 215
       12.1    Objectives of Compliance Tests       ...................................... 215
       12.2    Organization of the Compliance-Process  ........................... 216
      12.2.1   Authorities for the Compliance Process         ............................ 216
      12.2.2   Workflow of the Compliance Process ................................ 217
       12.3    Physical Layer Compliance Tests  ..................................... 218
       12.4    Core Compliance Tests     ................................................. 220
       12.5    Profile Compliance Tests  ............................................... 222
       12.6    Interoperability Tests  ................................................... 222
13    Survey of the MOST Specifications ............................................ 224
       13.1    Structure .................................................................. 224
       13.2    MOST Specification    ..................................................... 225
       13.3    MOST Dynamic Specification .......................................... 226
       13.4    MOST Function Catalog ................................................. 226
       13.5    MOST Compliance Test Specifications          .............................. 228
       13.6    Further Specifications, Guidelines and Cookbooks  .............. 228
Part 2
MOST-Based Applications
14    Development Tools ................................................................ 233
       14.1    Development Tools ...................................................... 233
       14.2    Development Tools – Hardware         ...................................... 234
      14.2.1   SMSC OptoLyzer OL3025o ............................................. 234
      14.2.2   SMSC MOST PCI-Board  ................................................. 235
      14.2.3   Vector VN2610 MOST USB Interface ................................. 236
       14.3    Development Tools – Software        ....................................... 237
      14.3.1   SMSC OptoLyzer Suite .................................................. 237
14       Contents
       14.3.2  SMSC MOST Rapid Control        ............................................ 239
       14.3.3  SMSC MOST Radar      ...................................................... 240
       14.3.4  SMSC INIC Remote Viewer  ............................................. 241
       14.3.5  Vector CANoe.MOST      .................................................... 241
       14.3.6  MOST Editor  .............................................................. 242
15   Structure of a Simple MOST System          .......................................... 245
       15.1     Structure of the MOST System       ....................................... 245
       15.1.1  SMSC Amplifier 4 MOST ................................................ 246
       15.1.2  CD Changer  ............................................................... 248
       15.2     Configuration of the Components  ................................... 248
       15.2.1  MOST Routing Table (MRT) ............................................. 249
       15.2.2  System Function Blocks ................................................ 249
       15.3     HMI ........................................................................ 251
       15.3.1  Development of the HMI with SMSC MOST RapidControl                  ....... 251
       15.3.2  Development of the HMI with Vector CANoe.MOST                .............. 257
       15.4    MOST System Extensions  .............................................. 263
16   Gateways to MOST  ................................................................ 264
       16.1    Distribution of Signals via a Gateway       ............................... 264
       16.2    Architecture of a Gateway     ............................................. 265
       16.3    MOST – CAN Gateway       .................................................. 266
       16.4    MOST – Bluetooth Gateway  ........................................... 267
       16.5    Routing of the Control Channel  ....................................... 268
       16.5.1  Routing of the Synchronous Audio Channels  ...................... 269
17   Manufacturing and Processing of MOST Components  .................... 271
       17.1    Elements, Structure and Testing of Opto-Electronic MOST
               Components .............................................................. 271
       17.1.1  Header  ..................................................................... 272
       17.1.2  Set of Fibers .............................................................. 274
       17.1.3  Connectors ................................................................ 279
       17.2    Processing within the Scope of Electronics Manufacture  ....... 280
       17.2.1  Mounting and Soldering of Headers ................................. 280
       17.2.2  Mounting and Soldering of Connectors ............................. 281
       17.2.3  Mounting of Internal Sets of Fibers  .................................. 281
       17.2.4  Device Testing  ............................................................ 282
       17.3    Summary  .................................................................. 282
18   MOST in Volume Production  .................................................... 283
       18.1    Architecture ............................................................... 283
       18.1.1  Network Topology with a Central Gateway           ......................... 283
        Contents          15
        18.1.2 System Definition    ....................................................... 284
        18.1.3 Migration .................................................................. 286
       18.2    Communication Characteristics of the Gateway              .................. 288
        18.2.1 Group Addresses  ........................................................ 288
        18.2.2 TP and BAP Communication ........................................... 289
       18.3    Software Test and Software Update          ................................. 289
        18.3.1 Software Test  ............................................................. 290
        18.3.2 Software Update ......................................................... 290
       18.4    Optical Physical Layer  .................................................. 291
       18.5    Basic Functions  .......................................................... 292
        18.5.1 Power Management ..................................................... 292
        18.5.2 Wake-Up ................................................................... 295
       18.6    Error Analysis ............................................................. 299
        18.6.1 Wake-Up Analysis     ....................................................... 299
        18.6.2 All-Slave Network ........................................................ 300
       18.7    Communication Diagnosis and Ring Break Diagnosis  ........... 301
       18.8    System Stability   ......................................................... 303
        18.8.1 Resource De-Allocate-All  ............................................... 304
        18.8.2 Double Call of Functions Allocate/DeAllocate and Connect/
               DisConnect (Handling of Double Commands)  ..................... 304
19    Sound Systems in Cars ........................................................... 306
       19.1    Sound Systems     .......................................................... 306
       19.2    Requirements of an Audio System ................................... 309
       19.3    Transmission Formats      .................................................. 311
Appendix
A     Comparison between MOST, Ethernet and IEEE 1394  ..................... 317
      A.1      Abstraction Model for a Comparison  ................................ 317
      A.2      System Architecture ..................................................... 318
      A.3      Software Architecture ................................................... 325
      A.4      Technology ................................................................ 326
      A.5      Examination of performance with regard to multimedia
               applications  .............................................................. 328
      A.6      Additional Implications of the Systems ............................. 332
      A.7      Conclusion  ................................................................ 334
B     Important Communication Systems ........................................... 335
      B.1      CAN ......................................................................... 335
      B.1.1    History  ..................................................................... 335
16        Contents
      B.1.2     The Concept      .............................................................. 336
      B.1.3     Arbitration    ................................................................ 337
      B.1.4     Protocol .................................................................... 338
      B.1.5     CAN-B  ...................................................................... 339
      B.1.6     CAN-C  ...................................................................... 339
      B.2       Bluetooth     ................................................................. 340
      B.2.1     History  ..................................................................... 340
      B.2.2     Technology ................................................................ 340
      B.2.3     Networking ................................................................ 341
      B.2.4     Bluetooth Protocol Stacks  ............................................. 342
      B.2.5     Bluetooth Car Profile .................................................... 344
      B.3       FlexRay [Meh 2004]  ..................................................... 346
      B.3.1     History  ..................................................................... 347
      B.3.2     Technology ................................................................ 347
      B.3.3     Data Transmission ....................................................... 347
      B.3.4     “Global Time” and Clock Synchronization .......................... 348
      B.3.5     Physical Layer  ............................................................ 349
      B.3.6     Networking ................................................................ 350
      B.3.7     Outlook  .................................................................... 351
      B.4       LIN  .......................................................................... 352
      B.4.1     History  ..................................................................... 352
      B.4.2     Most important Features of LIN ....................................... 353
C     Abbreviations      ...................................................................... 357
D     Glossary  ............................................................................. 362
E     Bibliography ........................................................................ 369
Index  ....................................................................................... 379
MOST_BOOK.part1.rar (15 MB , 下载次数: 236 )
MOST_BOOK.part2.rar (658.92 KB , 下载次数: 95 )
发表于 2011-2-9 20:28:58 | 显示全部楼层
good reference for automobile network
发表于 2011-2-12 09:48:41 | 显示全部楼层
下来看看,谢谢。
头像被屏蔽
发表于 2011-4-10 18:39:28 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-4-29 14:49:01 | 显示全部楼层
好资料,正想学习一下。
发表于 2011-7-1 01:02:33 | 显示全部楼层
多谢吧!
发表于 2012-1-8 14:15:08 | 显示全部楼层
还可以的书
发表于 2012-3-17 17:53:15 | 显示全部楼层
不错,正好要做most的相关产品
发表于 2012-4-20 14:59:12 | 显示全部楼层
先下来看看,谢谢楼主
发表于 2015-9-2 02:25:39 | 显示全部楼层
thnx!
GMT+8, 2025-12-18 03:23 , Processed in 0.027028 second(s), 8 queries , Gzip On, Redis On.
