楼主: wjx197733
分析SNDR、THD、SFDR、ENOB的matlab程序
发表于 2019-3-9 08:58:49 | 显示全部楼层
回复 1# wjx197733
    format long g;
clc;
SampleNumber=2^10;
SampleFrequency=50e6;
SingleFrequency=1.611328125e6;%537.109375e3;
vi=load('.\adc_sin.txt');
Vin=reshape(vi,'',1)';%'
Vin=Vin-(max(Vin(70:end))+min(Vin(70:end)))/2;
figure(1);
hold on;
plot(Vin(70:SampleNumber+69));
numpt2=fix(SampleNumber/2);
Dout=Vin(70:SampleNumber+69);
Window=kaiser(SampleNumber,10)';%'
span=5;
Doutw=Dout.*Window;
DoutFFT=fft(Doutw,SampleNumber);
SumPower=(abs(DoutFFT)).*(abs(DoutFFT));
SumPower_dB=10*log10(SumPower);
[MaxdB,SingleFrequencyPoint]=max(SumPower_dB(1:numpt2));
spanh=3;
DcPower=sum(SumPower(1:span));
if SingleFrequencyPoint>span
    SinglePower=sum(SumPower(SingleFrequencyPoint-span:SingleFrequencyPoint+span));
else
    SinglePower=0;
end
SingleHarmonyNumber2=floor(SampleNumber/SingleFrequencyPoint);%或者为SampleFrequency/(SingleFrequency)
SingleHarmonyPower=zeros(SingleHarmonyNumber2);
SingleHarmonyPower(1)=SinglePower;
SingleHarmonyFrequency=zeros(SingleHarmonyNumber2);
SingleHarmonyFrequency(1)=SampleFrequency*(SingleFrequencyPoint)/SampleNumber;
SingleHarmonyStep=SingleFrequencyPoint;
for SingleHarmonyNumber=1:SingleHarmonyNumber2/2;
    if (SingleHarmonyStep<=0) break; end
    HarmonyFrequencyPoint=SingleHarmonyStep*SingleHarmonyNumber+SingleFrequencyPoint
    if (HarmonyFrequencyPoint<=numpt2)
        if SingleHarmonyNumber==1;
            BaseHarmonyFrequencyPoint=HarmonyFrequencyPoint;
        end
        SingleHarmonyPower(SingleHarmonyNumber+1)=sum(SumPower(HarmonyFrequencyPoint-spanh:HarmonyFrequencyPoint+spanh));
        SingleHarmonyFrequency(SingleHarmonyNumber+1)=(HarmonyFrequencyPoint)*SampleFrequency/SampleNumber;
    end
end
SingleFrequency=SingleHarmonyFrequency(1);
HarmonyPowerNumber=floor(SampleNumber/SingleFrequencyPoint)/2;%或者为SampleFrequency/(SingleFrequency)/2
HarmonyPower=sum(SingleHarmonyPower(1:HarmonyPowerNumber))-SingleHarmonyPower(1);
NoisePower=sum(SumPower(1:numpt2))-DcPower-SinglePower;
ss=sqrt((sum(Dout.^2)/sum(Doutw.^2))*NoisePower*2)/SampleNumber%*sqrt(12)
HarmonyRange=floor(SampleNumber/SingleFrequencyPoint)/2;%或者为SampleFrequency/(SingleFrequency)/2
SNDR=10*log10(SinglePower/NoisePower);
THD=10*log10(HarmonyPower/SingleHarmonyPower(1))
SFDR=10*log10(SingleHarmonyPower(1)/max(SingleHarmonyPower(2:HarmonyRange)));
ENOBloc=(SNDR-1.76)/6.02;
figure(2);
hold on;
semilogx([0:numpt2-1]*SampleFrequency/SampleNumber,SumPower_dB(1:numpt2),'-r');
text_handle = text(floor(SampleFrequency/3),10, sprintf('SNDR = %4.1f dB \nENOB = %2.2f bits ',SNDR,ENOBloc), ...
    'EdgeColor','red','LineWidth',3,'BackgroundColor',[1 1 1],'Margin',10);
title('FREQ DOMAIN');
xlabel('ADC FFT SPECTRUM');
ylabel('AMPLITUDE(dB)');
发表于 2019-5-8 15:08:36 | 显示全部楼层
多谢分享
发表于 2019-5-27 22:02:28 | 显示全部楼层
下来看看
发表于 2019-6-10 13:32:41 | 显示全部楼层
thank you very much
发表于 2019-7-19 10:05:25 | 显示全部楼层
正好需要,感谢楼主。
发表于 2019-8-19 13:52:27 | 显示全部楼层
谢谢分享!!!
发表于 2019-8-22 14:46:36 | 显示全部楼层
See see. Thanks
发表于 2019-8-23 17:48:27 | 显示全部楼层
thank you
发表于 2019-8-27 13:20:55 | 显示全部楼层
分析SNDR、THD、SFDR、ENOB的matlab程序  谢谢分享
发表于 2019-8-28 10:48:50 来自手机 | 显示全部楼层
感谢楼主
GMT+8, 2025-12-18 22:56 , Processed in 0.018530 second(s), 3 queries , Gzip On, Redis On.
