查看: 2608|回复: 1
vcs_200906 安装求助!
发表于 2011-2-7 13:22:43 | 显示全部楼层 |阅读模式
ubuntu 10.10 安装vcs_vC-2009.06,有两个包:vcs_vC-2009.06_common和vcs_vC-2009.06_linux
安装快结束时,提示有错,查看install.log:
DO_INSTALL /home/eda/synopsys/vcs200906/VMS/admin/install.sh -r /home/eda/synopsys/vcs200906 -plat "linux"
ERROR : Failed to execute  /home/eda/synopsys/vcs200906/VMS/admin/install.sh
ERROR :
Start VMS/admin/install.sh
untar var.tar.gz  ...
untar samples.tar.gz ...
setting synopsys_rman.setup ...
Platform linux dependent code found
chmod: cannot access `var': No such file or directory   //不知什么意思
论坛上有人说,这个错误可以忽略,不影响使用。设置环境变量:
export VCS_HOME=/home/eda/synopsys/vcs200906
export PATH=$VCS_HOME/binPATH
export SNPSLMD_LICENSE_FILE=/home/eda/synopsys/license/synopsys.dat    //  license设置应该没有问题,
export LM_LICENSE_FILE=/home/eda/synopsys/license/synopsys.dat   //  安装的dc、primetime都可以使用!
   不知有没有设置错误,请高手指出。
下面开始编译.v文件:
dc@ubuntu:~/ALU$ vcs -Mupdate -RI div5.v div5_test.v    //对div5.v和div5_test.v 编译并启动Virsim(本人是初学者,不知对不对)
/bin/sh: Illegal option -h
                         Chronologic VCS (TM)
            Version C-2009.06 -- Sun Feb  6 21:09:15 2011
               Copyright (c) 1991-2008 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Warning-[ACC_CLI_ON] ACC/CLI capabilities enabled
  ACC/CLI capabilities have been enabled for the entire design. For faster
  performance enable module specific capability in pli.tab file
Parsing design file 'div5.v'
Parsing design file 'div5_test.v'
Top Level Modules:
       div5_test
TimeScale is 1 ns / 1 ns
Starting vcs inline pass...
1 module and 0 UDP read.
However, due to incremental compilation, no re-compilation is necessary.
make: *** [rmapats_mop.o] Error 2
Make exited with status 2
CPU time: .380000 seconds to compile + .300000 seconds to elab + 0 seconds to link
set: 1: Illegal option -h
可能的问题的地方,用红色标出,希望高手指出。
发表于 2011-2-12 23:03:47 | 显示全部楼层
1. sudo rm -rf /bin/sh
2. sudo ln -s /bin/bash /bin/sh
GMT+8, 2025-12-19 01:26 , Processed in 0.021039 second(s), 7 queries , Gzip On, Redis On.
