楼主: fumes
[求助] rail to rail 输出级用到的悬浮电流镜的作用是什么?怎么工作的?
发表于 2010-12-31 06:12:31 | 显示全部楼层
Correction
M24 and M26 are subject to ESD design rule.  (same L, not minimum, extended drain contact distance to poly edge, non-mimimum source-side contact distance to poly edge)
M21 and M25 are subject to ESD design rule. (same guideline as above)
M23 tracks M19 Vth, including body effect.
M22 tracks M22 Vth, including body effect.
发表于 2010-12-31 10:17:57 | 显示全部楼层
    说的不错,把这个经典classAB的原理讲的很清楚了。
    建议搂主好好看看书。
发表于 2010-12-31 10:55:30 | 显示全部楼层
rail to rail 的运放我最近也在研究,感觉遇到瓶颈了!
发表于 2011-1-5 06:53:02 | 显示全部楼层
same as classic AB stage
 楼主| 发表于 2011-1-5 13:42:54 | 显示全部楼层
这种mos管电路的线性度好不好啊?
发表于 2011-1-5 17:34:52 | 显示全部楼层
线性度比class A 差
 楼主| 发表于 2011-1-20 11:14:07 | 显示全部楼层
sdfsdfsdf
发表于 2011-1-20 19:52:21 | 显示全部楼层
hao a xiexie a
发表于 2011-1-21 05:51:12 | 显示全部楼层
主要能保证M25和M26的电流相等就可以了,保证输出共模电压正确
发表于 2011-1-21 07:38:25 | 显示全部楼层
There are two translinear loops in it.
1) M20,M21,M22,M25 and also 2) M19,M23,M24, M26.
In quiesenct current calculation, the currents go through M19/M20 are equal. This tail-to-head coupling controls the minimum current of the output tansistor.
GMT+8, 2025-12-24 03:54 , Processed in 0.024297 second(s), 4 queries , Gzip On, Redis On.
