查看: 3211|回复: 2
[招聘] 和芯星通招聘Senior Ic Design Engineer和senior embedded Software Engineer
发表于 2010-12-16 14:18:40 | 显示全部楼层 |阅读模式
Position and Responsibility:
Position: IC Design Engineer
LocationShanghai
Headcount: 5
Report To: IC Design Manager
[/td][/tr]
Responsibility:
Digital circuit design and specification define
RTL coding and verification
  • Block level synthesis and whole chip synthesis
  • Back-end design related support
  • Pre-/Post-layout STA and simulation.
  • Chip bring up and validation
  • Support verification engineer in building test vector on ATE
  • Support PSV team in silicon test
[/td][/tr]
Education and skill requirements:
  • MSEE/MSCS Degree or equivalent
  • Well knowledgeable in digital/Analog circuit design and digital signal process
  • Be familiar with C/C++, Have experience in embedded software is a plus
  • Be familiar with standard CAD tools, such as VCS/NCverilog/ Design compiler
  • Knowledgeable in ASIC design/verification methodology
  • Excellent analytical and problem solving skills
  • Must be a self motivated, energetic individual who takes pride and ownership in their work.
  • Innovative thinking and team working spirit.
  • Be initiative, capable to analyze and learn
  • High team and result orientation are required.
  • Know how to share knowledge with other colleagues.
  • Fluent speaking and writing skills in English
[/td][/tr]
Position: Senior IC Design EngineerLocationShanghaiHeadcount: 5Report To: IC Design Manager
Responsibility:·
Block level Micro-architecture definition.
  • Block level synthesis ,constraint generation and maintenance and whole chip synthesis support
  • Help on test plan development to guarantee IP fully tested.
  • More than 3 years experience in hands-on ASIC design
  • Track record of 1+ successful tape-out of million-gates or above ASIC
JD Senior Embedded Software Enginner.pdf (22.24 KB , 下载次数: 6 )
如果您有兴趣麻烦发简历到recruiting@unicorecomm.com,我们会尽快联系您 有任何问题我们也会给您解答~谢谢!
发表于 2010-12-16 22:49:17 | 显示全部楼层
我是做模拟的
发表于 2010-12-16 23:17:09 | 显示全部楼层
我是做数字的
GMT+8, 2025-9-19 08:15 , Processed in 0.018665 second(s), 8 queries , Gzip On, Redis On.
