在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3167|回复: 2
[求助] 【菜鸟求助】如何在HSPICE下用AVANWAVES看增益?
发表于 2010-12-11 23:04:05 | 显示全部楼层 |阅读模式
如何绘出频率和差模增益AV的关系图??
我使用公示生成器,用输出电压的除以减去输入电压的差,却提示我除数为0不能生成。。求教!
谢谢
发表于 2010-12-12 04:42:34 | 显示全部楼层
Question:
Did you use ".ac" card in your simulation deck?
Normally when one wants to check frequency response and differential gain, he/she uses ".ac" card.
He/she specifies one terminal of the signal source without AC source (say, the negative terminal), with another (say, the positive terminal) with AC source specified as 1.
Thus the phase shift at the output node (or the nodes he/she concerns) corresponds to the phase lag compared with the positive terminal of the differential circuit.
Then he/shes normally uses ".probe" card with "vdb(NODE_NAME)" and "vp(NODE_NAME)" as parameters.
Could you please post your simulation deck?
发表于 2014-12-4 12:09:17 | 显示全部楼层
use log axis !
小黑屋| 手机版| 关于我们| 联系我们| 在线咨询| 隐私声明| EETOP 创芯网
GMT+8, 2024-11-16 20:40 , Processed in 0.016358 second(s), 8 queries , Gzip On, Redis On.
