楼主: microsofthard
[2009][软件][Mentor][Catapult C Synthesis][2009a.168][破解][原创]
发表于 2010-12-16 19:13:44 | 显示全部楼层
多谢楼主啦~O(∩_∩)O~
发表于 2010-12-16 19:52:08 | 显示全部楼层
囧。。。不行啊,在安装的时候到verify的那一步出现:
No products are available (License request failed, scroll down for details).
The verification error could be due to one or more of the following:
        1) Path to the license server is incorrect
        2) License server not running or inaccessible
        3) License sever must be updated
        4) No Catapult authorization codes exist in the license file
        5) Existing Catapult licenses are already checked out by other users
If you need to setup or upgrade your license server the files can be found in the installation tree.These files are available even if you cancel this setup wizard.  You may first need to install another platform to obtain the necessary licensing executables for your license server platform.
Please refer to the Installation and Licensing Manuals for further information on license configuration.
Licensing Messages:
        Error: License verification failed, pid = catapultcoresl, (feature unavailable)
        Error: License request for catapultcoresl feature failed
        Error: License verification failed, pid = catapultcorebl, (feature unavailable)
        Error: License request for catapultcorebl feature failed
        Error: License verification failed, pid = catapultcoreuv, (feature unavailable)
        Error: License request for catapultcoreuv feature failed
        Error: License verification failed, pid = catapultcorep1, (feature unavailable)
        Error: License request for catapultcorep1 feature failed
        Error: License verification failed, pid = catapultcorep2, (feature unavailable)
        Error: License request for catapultcorep2 feature failed
        Error: License verification failed, pid = catapultoemalt, (feature unavailable)
        Error: License request for catapultoemalt feature failed
        Error: License verification failed, pid = catapultcorep3, (feature unavailable)
        Error: License request for catapultcorep3 feature failed
        Error: License verification failed, pid = catapultcorep4, (feature unavailable)
        Error: License request for catapultcorep4 feature failed
        Error: License verification failed, pid = catapultlbcore, (feature unavailable)
        Error: License request for catapultlbcore feature failed
ps:license server已经正常启动。。。
 楼主| 发表于 2010-12-16 20:14:31 | 显示全部楼层
回复 12# sunward
    是会这样,这个破解软件是有问题,我在同学机子上也遇到,首先先确保server启动成功,进程里面应该包含LMGRD和MGCLD!!
查看log文件应该如下:
10:04:18 (lmgrd) -----------------------------------------------
10:04:18 (lmgrd)   Please Note:
10:04:18 (lmgrd)
10:04:18 (lmgrd)   This log is intended for debug purposes only.
10:04:18 (lmgrd)   In order to capture accurate license
10:04:18 (lmgrd)   usage data into an organized repository,
10:04:18 (lmgrd)   please enable report logging. Use Macrovision's
10:04:18 (lmgrd)   software license administration  solution,
10:04:18 (lmgrd)   FLEXnet Manager, to  readily gain visibility
10:04:18 (lmgrd)   into license usage data and to create
10:04:18 (lmgrd)   insightful reports on critical information like
10:04:18 (lmgrd)   license availability and usage. FLEXnet Manager
10:04:18 (lmgrd)   can be fully automated to run these reports on
10:04:18 (lmgrd)   schedule and can be used to track license
10:04:18 (lmgrd)   servers and usage across a heterogeneous
10:04:18 (lmgrd)   network of servers including Windows NT, Linux
10:04:18 (lmgrd)   and UNIX. Contact Macrovision at
10:04:18 (lmgrd)   www.macrovision.com for more details on how to
10:04:18 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
10:04:18 (lmgrd)   for your enterprise.
10:04:18 (lmgrd)
10:04:18 (lmgrd)
10:04:18 (lmgrd)
10:04:18 (lmgrd) pid 2148
10:04:18 (lmgrd) Done rereading
10:04:18 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_n3) started on june (IBM PC) (12/15/2010)
10:04:18 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
10:04:18 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:04:18 (lmgrd) World Wide Web:  http://www.macrovision.com
10:04:18 (lmgrd) License file(s): D:\Mentor Graphics\Catapult Synthesis 2009a.168 Production Release\Mgc_home\license.dat
10:04:18 (lmgrd) lmgrd tcp-port 27001
10:04:18 (lmgrd) Starting vendor daemons ...
10:04:19 (lmgrd) Started mgcld (pid 3412)
10:04:22 (mgcld) Server started on june for: mgc_s
10:04:22 (mgcld) mentorall_s falconfw_s design_s
………………………………(很多很多)
22:30:34 (mgcld)
22:30:34 (mgcld) Licenses are case sensitive for mgcld
22:30:34 (mgcld)
22:30:34 (mgcld) EXTERNAL FILTERS are OFF
22:30:34 (lmgrd) mgcld using TCP-port 4837
这个说明server启动真的成功了,我发现可能server会没有被启动。
其次,在这种情况下,如果发生上面的情况,就重新点float.bat,不断得重新生成license,直到成功为止!
我发现每次生成的license序列号是不一样的。。。。。汗。。。一般10次总能成功的,汗。。。。
 楼主| 发表于 2010-12-16 20:26:39 | 显示全部楼层
回复 12# sunward
20:21:38 (mgcld) OUT: "mgc_s" June@june
20:21:38 (mgcld) OUT: "catapultbeta2" June@june
如果license是可以的,你看log里面最后出现就是这样的OUT IN信息,
否则会有(unsupported)字眼。。。。不断用FLoat.bat换license肯定能成功的。
我倒是遇到过显示启动server成功,但其实没有真的启动,进程里面没有。
你可以将Mgc_home/lib/下面的MGCLD.EXE复制到/Mgc_HOME/bin下面,手动双击LMGRD.EXE,启动。如果license manager就启动成功,看一下进程和log里面是不是真的有吧~
反正license要点几次就是看RP了。。。。。
发表于 2010-12-16 23:52:35 | 显示全部楼层
good,look
发表于 2010-12-17 08:15:23 | 显示全部楼层
ddddddddddddddddddddddddddddddddd
发表于 2010-12-17 22:55:14 | 显示全部楼层
多谢楼主分享。我破解的时候在“修改LM_LICENSE_FILE环境变量”这一步中,怎么找不到".log"文件?
发表于 2010-12-18 12:47:03 | 显示全部楼层
可是我只想把license解出来啊,希望有人贡献一下!
发表于 2010-12-19 01:11:31 | 显示全部楼层
thank you for it
发表于 2010-12-19 01:13:10 | 显示全部楼层
非常感谢!正在找这个东东啊!下来看看。
GMT+8, 2025-12-22 09:40 , Processed in 0.019552 second(s), 3 queries , Gzip On, Redis On.
