查看: 15935|回复: 13
[求助] delsig (Delta Sigma Toolbox)工具包使用问题
发表于 2010-11-18 11:02:50 | 显示全部楼层 |阅读模式
我downlown的工具包http://bbs.eetop.cn/viewthread.php?tid=61543&highlight=delsig
将工具包加载到matlab路径中
执行mex simulateDSM.c、mex simulateESL.c和mex ai2mif.c
在执行mex ai2mif.c时报lcc preprocessor error: ai2mif.c:68 Could not find include file <strings.h> 错误
因为icc中无strings.h,将68删除,加载通过
但是转换matlab路径到C:\Program Files\MATLAB71\work
执行ntf=synthesizeNTF(5,32,1)
报??? Undefined command/function 'synthesizeNTF'.错误
不知大家遇到这么问题没?怎么解决?谢谢
发表于 2010-11-18 13:17:08 | 显示全部楼层
good reference material
发表于 2011-4-30 11:07:39 | 显示全部楼层
I also found "strings.h" not supported and I tried to mark off this declaration, before I issue the mex command, but I did bump into the same mex compilation error.
My suggestion is simply not to alter the code in file ai2mif.c, and leave this file uncompiled.
I also tried to "mex simulateDSM.c" and "mex simulateESL.c" only and the Delta-Sigma Toolbox demos "dsdemo1" worked as well.
发表于 2012-2-27 13:58:49 | 显示全部楼层
我有碰到这个问题了~~~求解决~~~
发表于 2012-11-14 11:41:57 | 显示全部楼层
这个问题解决了么?  我的是在mex simulateDSM.c 的时候出了error:'simulateDSM.c' not found 能给说下是啥问题么?
发表于 2014-4-26 14:47:47 | 显示全部楼层
回复 3# fhchen2002
您好,我现在在学习delta-sigma toolbox,在运行mex
simulateDSM.c 时报错, 说'simulateDSM.c' 这个没有找到
但是我已经把路径添加进去了   具体错误是:  Error : ‘xxx.c’  not found
???  Error using mex (line 206)
Unable to complete successfully.求解答啊!
发表于 2014-4-26 14:48:24 | 显示全部楼层
回复 1# scy8080
发表于 2017-1-18 10:08:23 | 显示全部楼层
回复 7# 673741088
   请直接到delsig目录下运行 "mex simulateDSM.c" and "mex simulateESL.c"
发表于 2018-10-17 17:15:54 | 显示全部楼层
回复 1# scy8080
   谢谢,不错的
发表于 2018-10-17 23:58:38 | 显示全部楼层
很好的设计工具
GMT+8, 2025-12-18 22:03 , Processed in 0.021565 second(s), 3 queries , Gzip On, Redis On.
