查看: 4326|回复: 4
[资料] 3GPP TS 25.214
发表于 2010-11-9 03:53:02 | 显示全部楼层 |阅读模式
3rd Generation Partnership Project;
Technical Specification Group Radio Access Network;
Physical layer procedures (FDD)
(Release 9)
The present document specifies and establishes the characteristics of the physicals layer procedures in the FDD mode of
UTRA.
1 Scope .................................................................................................................................................. 7
2 References .......................................................................................................................................... 7
3 Definitions and Abbreviations ............................................................................................................. 7
3.1 Definitions ................................................................................................................................................... 7
3.2 Abbreviations............................................................................................................................................... 8
4 Synchronisation procedures................................................................................................................. 9
4.1 Cell search ................................................................................................................................................... 9
4.2 Common physical channel synchronisation ................................................................................................... 9
4.2.1 P-CCPCH radio frame timing.................................................................................................................. 9
4.2.2 S-CCPCH soft combining timing ............................................................................................................ 9
4.2.3 Radio frame timing on the MBSFN layer ................................................................................................ 9
4.2.4 Secondary serving HS-DSCH cell timing ................................................................................................ 9
4.3 DPCCH/DPDCH/F-DPCH synchronisation .................................................................................................. 9
4.3.1 Synchronisation primitives ...................................................................................................................... 9
4.3.1.1 General ............................................................................................................................................. 9
4.3.1.2 Downlink synchronisation primitives ............................................................................................... 10
4.3.1.3 Uplink synchronisation primitives.................................................................................................... 11
4.3.2 Radio link establishment and physical layer reconfiguration for dedicated channels ............................... 11
4.3.2.1 General ........................................................................................................................................... 11
4.3.2.2 Node B radio link set state machine ................................................................................................. 12
4.3.2.3 Synchronisation procedure A ........................................................................................................... 12
4.3.2.3A Synchronisation procedure AA ........................................................................................................ 13
4.3.2.4 Synchronisation procedure B ........................................................................................................... 14
4.3.3 Radio link monitoring ........................................................................................................................... 14
4.3.3.1 Downlink radio link failure .............................................................................................................. 14
4.3.3.2 Uplink radio link failure/restore in CELL_DCH state ....................................................................... 14
4.3.3.2A Uplink radio link failure/restore in CELL_FACH state and IDLE mode ........................................... 15
4.3.4 Transmission timing adjustments .......................................................................................................... 15
5 Power control.................................................................................................................................... 15
5.1 Uplink power control ................................................................................................................................. 15
5.1.1 PRACH ................................................................................................................................................ 15
5.1.1.1 General ........................................................................................................................................... 15
5.1.1.2 Setting of PRACH control and data part power difference ................................................................ 15
5.1.2 DPCCH/DPDCH .................................................................................................................................. 16
5.1.2.1 General ........................................................................................................................................... 16
5.1.2.2 Ordinary transmit power control ...................................................................................................... 16
5.1.2.2.1 General ...................................................................................................................................... 16
5.1.2.2.2 Algorithm 1 for processing TPC commands................................................................................ 18
5.1.2.2.3 Algorithm 2 for processing TPC commands................................................................................ 18
5.1.2.3 Transmit power control in compressed mode ................................................................................... 20
5.1.2.4 Transmit power control in the uplink DPCCH power control preamble ............................................. 22
5.1.2.5 Setting of the uplink DPCCH/DPDCH relative powers..................................................................... 23
5.1.2.5.1 General ...................................................................................................................................... 23
5.1.2.5.2 Signalled gain factors ................................................................................................................. 23
5.1.2.5.3 Computed gain factors ............................................................................................................... 23
5.1.2.5.4 Setting of the uplink DPCCH/DPDCH relative powers in compressed mode ............................... 24
5.1.2.5A Setting of the uplink HS-DPCCH power relative to DPCCH power .................................................. 24
5.1.2.5B Setting of the uplink E-DPCCH and E-DPDCH powers relative to DPCCH power ........................... 26
5.1.2.5B.1 E-DPCCH/DPCCH .................................................................................................................... 26
5.1.2.5B.2 E-DPDCH/DPCCH .................................................................................................................... 27
5.1.2.5C Setting of the uplink DPCCH gain factor when no DPDCH is configured ......................................... 32
5.1.2.6 Maximum and minimum power limits ............................................................................................. 32
5.1.3 Void ..................................................................................................................................................... 34
5.2 Downlink power control ............................................................................................................................. 34
5.2.1 DPCCH/DPDCH/F-DPCH .................................................................................................................... 34
5.2.1.1 General ........................................................................................................................................... 34
5.2.1.2 Ordinary transmit power control ...................................................................................................... 34
5.2.1.2.1 UE behaviour ............................................................................................................................. 34
5.2.1.2.2 UTRAN behaviour ..................................................................................................................... 35
5.2.1.3 Power control in compressed mode .................................................................................................. 36
5.2.1.4 Void ................................................................................................................................................ 37
5.2.2 Void ..................................................................................................................................................... 37
5.2.3 Void ..................................................................................................................................................... 37
5.2.4 AICH ................................................................................................................................................... 37
5.2.5 PICH .................................................................................................................................................... 37
5.2.6 S-CCPCH ............................................................................................................................................. 37
5.2.7 Void ..................................................................................................................................................... 38
5.2.8 Void ..................................................................................................................................................... 38
5.2.9 Void ..................................................................................................................................................... 38
5.2.10 HS-SCCH ............................................................................................................................................. 38
5.2.11 HS-PDSCH .......................................................................................................................................... 38
5.2.12  E-AGCH .............................................................................................................................................. 38
5.2.13  E-HICH ................................................................................................................................................ 38
5.2.14  E-RGCH............................................................................................................................................... 38
5.2.15 MICH ................................................................................................................................................... 38
5.2.16 S-CPICH .............................................................................................................................................. 38
6 Random access procedure ................................................................................................................. 39
6.1 Physical random access procedure .............................................................................................................. 39
6.1.1 RACH sub-channels ............................................................................................................................. 40
6.1.2  RACH access slot sets .......................................................................................................................... 40
6.1A Physical random access procedure for Enhanced Uplink in CELL_FACH state and IDLE mode .................. 41
6.2 Void .......................................................................................................................................................... 43
6A  HS-DSCH-related procedures ........................................................................................................... 43
6A.1 General procedure ...................................................................................................................................... 43
6A.1.1 UE procedure for receiving HS-DSCH and HS-SCCH in the CELL_DCH state ..................................... 44
6A.1.1A UE procedure for receiving HS-DSCH and HS-SCCH in CELL_FACH state ........................................ 46
6A.1.1B UE procedure for receiving HS-DSCH and HS-SCCH in the URA_PCH and CELL_PCH states ........... 47
6A.1.2 UE procedure for reporting channel quality indication (CQI) and precoding control indication (PCI) ..... 47
6A.1.2.1 CQI reporting procedure in case the UE is not configured in MIMO mode ....................................... 47
6A.1.2.2 Composite PCI/CQI reporting procedure in case the UE is configured in MIMO mode ..................... 48
6A.1.3 Node B procedure for transmitting the HS-DSCH and HS-SCCH .......................................................... 49
6A.1.3.1 Node B procedure for transmitting the HS-DSCH and HS-SCCH in the CELL_DCH state ............... 49
6A.1.3.2 Node B procedure for transmitting the HS-DSCH and HS-SCCH in the CELL_FACH state ............. 50
6A.1.3.3 Node B procedure for transmitting the HS-DSCH and HS-SCCH in the URA_PCH or
CELL_PCH state ............................................................................................................................. 50
6A.2 Channel quality indicator (CQI) definition .................................................................................................. 51
6A.2.1 CQI definition when the UE is not configured in MIMO mode .............................................................. 51
6A.2.2  CQI definition when the UE is configured in MIMO mode .................................................................... 51
6A.2.3  CQI tables ............................................................................................................................................ 53
6A.3 Operation during compressed mode on the associated DPCH or F-DPCH ................................................... 64
6A.4 Precoding control indication (PCI) definition .............................................................................................. 64
6B E-DCH related procedures ................................................................................................................ 65
6B.1 ACK/NACK detection ............................................................................................................................... 66
6B.2 Relative grants detection ............................................................................................................................ 66
6B.3 E-DCH control timing ................................................................................................................................ 66
6B.3.1 10 ms E-DCH TTI ................................................................................................................................ 66
6B.3.2 2 ms E-DCH TTI .................................................................................................................................. 67
6B.4 Operation during compressed mode ............................................................................................................ 67
6B.4.1 Uplink compressed mode ...................................................................................................................... 67
6B.4.2 Downlink compressed mode ................................................................................................................. 68
6C Discontinuous transmission and reception procedures ....................................................................... 68
6C.1 Uplink CQI transmission ............................................................................................................................ 69
6C.2 Discontinuous uplink DPCCH transmission operation................................................................................. 69
6C.2.1 Uplink DPCCH burst pattern................................................................................................................. 70
6C.2.2 Uplink DPCCH preamble and postamble............................................................................................... 71
6C.2.2.1 Uplink DPCCH preamble and postamble for the DPCCH only transmission ..................................... 71
6C.2.2.2 Uplink DPCCH preamble and postamble for the E-DCH transmission .............................................. 71
6C.2.2.3 Uplink DPCCH preamble and postamble for the HS-DPCCH transmission....................................... 71
6C.3 Discontinuous downlink reception .............................................................................................................. 72
6C.4 HS-SCCH orders ........................................................................................................................................ 74
6C.5 Operation during compressed mode ............................................................................................................ 74
7 Closed loop mode 1 transmit diversity ............................................................................................... 74
7.1 General procedure ...................................................................................................................................... 75
7.2 Determination of feedback information....................................................................................................... 76
7.2.1 End of frame adjustment ....................................................................................................................... 77
7.2.2 Normal initialisation ............................................................................................................................. 77
7.2.3 Operation during compressed mode ...................................................................................................... 78
7.2.3.1 Downlink in compressed mode and uplink in normal mode .............................................................. 78
7.2.3.2 Both downlink and uplink in compressed mode................................................................................ 78
7.2.3.3 Uplink in compressed mode and downlink in normal mode .............................................................. 79
7.2.4 Initialisation during compressed mode .................................................................................................. 79
7.2.4.1 Downlink in compressed mode ........................................................................................................ 79
7.2.4.2 Uplink in compressed mode ............................................................................................................. 79
7.3 Void .......................................................................................................................................................... 80
8 Idle periods for IPDL location method .............................................................................................. 80
8.1 General ...................................................................................................................................................... 80
8.2 Parameters of IPDL .................................................................................................................................... 80
8.3 Calculation of idle period position .............................................................................................................. 80
9 MIMO operation of HS-DSCH ......................................................................................................... 82
9.1 General procedure ...................................................................................................................................... 84
25214-920.pdf
3.53 MB, 下载次数: 56 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-11-9 08:09:58 | 显示全部楼层
part four
发表于 2010-12-4 13:45:41 | 显示全部楼层
赦免版本
发表于 2015-10-28 09:18:50 | 显示全部楼层
很好的东西。
发表于 2016-10-14 11:17:15 | 显示全部楼层
thanks for your great share !
GMT+8, 2025-9-19 06:33 , Processed in 0.020369 second(s), 7 queries , Gzip On, Redis On.
