我在本论坛内下载的design compiler2008安装过程都正常,安装环境为ubuntu-10.04,shell为bash,安装完成之后终端运行dc启动不了,但运行dv却可以,终端提示如下:
---------------我是分割线---------------------
kexin-amy@kexin-amy-desktop:~$ dc
DC Professional (TM)
DC Expert (TM)
DC Ultra (TM)
FloorPlan Manager (TM)
HDL Compiler (TM)
VHDL Compiler (TM)
Library Compiler (TM)
DesignWare Developer (TM)
DFT Compiler (TM)
BSD Compiler
Power Compiler (TM)
Version Z-2007.03-SP5 for linux -- Oct 16, 2007
Copyright (c) 1988-2007 by Synopsys, Inc.
ALL RIGHTS RESERVED
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
The above trademark notice does not imply that you are licensed to use
all of the listed products. You are licensed to use only those products
for which you have lawfully obtained a valid license key.
Error: For optimal performance and to take advantage of the
latest enhancements and capabilities in Synopsys synthesis products,
we recommend the use of XG mode. XG mode is available in Tcl only.
DCSH mode will not be supported in future releases.
Information: If you want to use dc_shell in DCSH mode, please use
dc_shell -db_mode -dcsh_mode.
For more information, please go to http://solvnet.synopsys.com
kexin-amy@kexin-amy-desktop:~$ dv
DC Expert (TM)
DC Ultra (TM)
HDL Compiler (TM)
VHDL Compiler (TM)
DFT Compiler (TM)
BSD Compiler
Power Compiler (TM)
ALL RIGHTS RESERVED
Initializing...
Starting shell in XG mode...
design_vision-xg-t> design_vision-xg-t>
不知道为什么,我改过shell试了一下也还是不行,忘说了,环境变量设置如下:
#Design Compiler
#下面一行中的/usr/synopsys/dc200809 是 DC 安装目录
export PATH="/eda/synopsys/dc200809/bin:"$PATH
#lmgrd
#下面一行中的/usr/synopsys/scl 是 scl 安装目录
export PATH="/eda/synopsys/scl/linux/bin:"$PATH
export SYNOPSYS="/eda/synopsys/dc200809"
#下面两行是关联我们生成的 license,若没有这一步,软件会默认
#到/usr/local/flexlm/licenses 文件夹中去找 license
export SNPSLMD_LICENSE_FILE=/eda/synopsys/license/synopsys.dat
export LM_LICENSE_FILE=/eda/synopsys/license/synopsys.dat
alias sylic="/eda/synopsys/scl/linux/bin/lmgrd -c /eda/synopsys/license/synopsys.dat -l ~/syn_lic.log"
alias dc="dc_shell"
alias dv="design_vision"
哪位好心人指点一下吧......
谢谢了 |
