查看: 3972|回复: 2
[求助] questions about bandgap startup circuit
发表于 2010-10-20 19:44:54 | 显示全部楼层 |阅读模式
hi all,
i wanna do some research about the startup circuit of bandgap, please help me
1:how to analysis the numbers of the stable operating points of the circuit. as far as i know, some bandgap circuits have 2 stable operating points, some circuits have 3 stable operating points. I wanna know are there some methods to count the numbers of stable operating points?
2:how to analysis a kind of startup circuit can work properly? what kind of situation can make the bandgap circuit fail to startup?
3:is there any method to calculate the startup time and the overshot time?
any suggestion or any paper reference is highly appreciated.
ps: pls show me the paper download links, thanks all
 楼主| 发表于 2010-10-21 18:09:57 | 显示全部楼层
no one cares?
发表于 2010-10-22 19:29:57 | 显示全部楼层
you can refer this book:Voltage Reference - From Diode To High Precision High Order BandGap, it can be found here。
GMT+8, 2025-11-28 17:37 , Processed in 0.019341 second(s), 5 queries , Gzip On, Redis On.
