查看: 1962|回复: 1
[招聘] 外资公司需要高级/staff芯片验证人才
发表于 2010-8-5 13:36:01 | 显示全部楼层 |阅读模式
Job Title:
Sr/Staff Verification Engineer
Post Holder:
Reports To:
Sr. Manager, MFS Verification
Direct Reports:
0
No. of Indirect Reports:
0
Key Relationships (internal and external):
Internal:
IC Design, System Hardware, PM
External:
EDA company
Revenue / Budgetary Responsibility (where relevant):
0
Function:
Engineering
Shanghai
Job Purpose:
Take the lead role developing verification methodology, verification plan for SoC chips. And execute on the verification plan, achieving the best functional coverage.
Key Responsibilities:
Own multiple modules, sub-systems, create constrained random based, coverage targeted verification plan and verify them from unit level going towards chip level integration.
Own 3rd party IP verification/validation -- verify and validate them at unit, chip and system level.
Help automate verification/validation tasks, run regression, manage bug tracking, run and analyze functional and code coverage, achieve coverage goals, etc.
Support gate-level net-list functional and timing verification activities till tapeout.
Conduct pre-silicon validation on a FPGA platform.
Support test pattern generation and debugging for ATE testing.
Person Specification:
Required:
Desired:
  • Minimum 5 year of industry experience, minimum MS degree in Electrical/Computer engineering or equivalent.
  • In-depth knowledge of SoC/ASIC verification flow with emphasis in coverage driven verification/validation methodology.
  • Clear understanding of constrained random verification process, functional coverage, code coverage, assertion methodology and their philosophies.
  • Track record of picking up legacy verification environment and work on fully developed DV environment, as well as, developing DV environment from scratch.
  • In depth knowledge of ARM Instruction set and AMBA bus architecture.
  • Knowledge of C, assembly for ARM processor.
  • Intricate knowledge of Verilog, Verilog simulator and debug process.
  • Have hands-on experience on crafting complex verification environment with industry standard HVL based methodology (must have SystemC, SysVerilog, vera, or Specman-e based experience).
  • Track record of delivering multiple fully verified chips from concepts to tapeout.
  • Depth and breadth of knowledge on industry standard IO protocols: SPI, I2C, I2S, flash memories, SRAM and DRAM.
 楼主| 发表于 2010-8-9 09:37:20 | 显示全部楼层
up and up
GMT+8, 2025-12-14 18:48 , Processed in 0.016404 second(s), 7 queries , Gzip On, Redis On.
