查看: 2420|回复: 7
Metal Programmable ROM128kx8 in 0.35µm CMOS (C35/S35)
发表于 2010-8-4 23:49:22 | 显示全部楼层 |阅读模式
Key Features
  • Metal programmable ROM 128kx8 in 0.35µm CMOS Process (C35/S35)
  • Area optimized architecture
  • Synchronous interface / access
  • Two layer programmable (VIA1 & METAL1)
  • Triple metal layout of memory
  • 128k words
  • 8 bit databus
  • Simulation models for 3.3V nominal supply
Deliverables
  • Frontend services
    • CADENCE
      • cell library with symbol, functional, abstract and msps view
      • TLF 3.0 & TLF 4.3 timing data file
      • LEF file for silicon ensemble
      • SDF annotable Verilog model
    • SYNOPSYS
      • cell timing model (interface model)
  • Backend Services (on order)
    • CADENCE
      • cell library with additional layout view with reduced layout data (*)
    • gds2 data
      • reduced layout data in gds2 format (*)
    (*) reduced layout data does not contain the following layers:
    • Diffusion
    • Poly1
    • N+ Implant
    • P+ Implant
    • Contact
    The reduced layout data will be replaced with full layout data by austriamicrosystems before production.
Area
Area [mm2]
Process 128k x 8
C35 3.91
Timing
Access Time [ns]
Process 128k x 8
C35 9.5
Power consumption
Supply Current [mA/MHz]
Process 128k x 8
C35 0.25
Power and Timing data conditions:
  • typical process parameters
  • VDD = 3.3V
  • Tj = 25C
  • Cload = 1pF
Description
This instance is a VIA1 & MET1 programmable ROM device. The 2 layer programming concept guarantees a high density ROM block.
Please note: The instance is not included in the standard HIT-Kit shipment. Memory Simulation models can be downloaded free of charge, reduced layout data including connectivity and metal coverage information is provided after placement of a purchase order whereas the complete layout data of the ROM block will be inserted into your design by austriamicrosystems' Customer Engineering once you have submitted the GDSII database for manufacturing.
metROM128kx8_frontend.tar.gz
28.25 KB, 下载次数: 47 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-8-5 06:08:25 | 显示全部楼层
thanks for sharing!(--)!
发表于 2010-8-20 17:04:42 | 显示全部楼层
rom.............
发表于 2010-8-21 17:11:24 | 显示全部楼层
谢谢!!!!
发表于 2010-8-22 05:59:12 | 显示全部楼层
Thanks for sharing.
发表于 2013-10-15 09:20:36 | 显示全部楼层
谢谢分享!学习了。
发表于 2013-10-15 09:22:20 | 显示全部楼层
再顶!看了有了解。
发表于 2013-10-16 11:09:53 | 显示全部楼层
rom??
GMT+8, 2025-12-19 16:45 , Processed in 0.021821 second(s), 7 queries , Gzip On, Redis On.
