查看: 4358|回复: 2
[招聘] 【招聘】LSI上海研发中心诸多IC硬件工程师职业发展机会等着您!
发表于 2010-7-29 19:57:34 | 显示全部楼层 |阅读模式
全球著名硬件公司LSI上海研发中心正在扩张中,有很多硬件工程师的职业发展机会。
欢迎有志之士加入!如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.也可加我msn;zql975504@hotmail.com
有意者,请将简历发至:Tracey.zheng@lsi.com
1.
Verification Design Engineer
Responsible for Design, Verification and customer support of protocol systems. Good knowledge of High Speed Interconnects, Storage and Networking Protocols, such as PCI Express, Ethernet, Fibre Channel, Serial RIO, Interlaken. Good communication skill is must. Experience with FPGA prototyping/validation a plus.
PREFERRED EXPERIENCE:
Design skills:
- Micro-architecture development & RTL Design
- Synthesis & Timing analysis
Verification skills:
- Verification, including development of methodologies, test plans, compliance test suite, test bench & test cases, using System Verilog, Vera and Specman.
- Development of Bus Functional models (BFMs), transactors, assertions, and manage coverage and regressions
Standards development:
- Work with standards bodies such as IEEE and PCI SIG to develop industry standard specification for next generation product
Must be conversant with the following:
- Verilog, System Verilog, C++, EDA CAD tools,
- Synthesis, Timing constraints and Logic Equivalence
2. Test Engineer
JOB DESCRIPTION:
- To support prototype and production releases of new products. Manage debug of test program, design and debug of test hardware, and meet product release schedule.
- Support test program development for implementing changes in new test methodologies for test coverage improvement.
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via test time reduction and multiple site test solutions for production release.
- Support test chip test development and characterization of new IP used in LSI products.
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM, Fabless, or Foundry environment
- ATE programming skills would be essential
- C++ and/or Perl programming skills
3. ASIC Customer Design Engineer
JOB DESCRIPTION:
The Customer Design Engineer is a challenging and cutting-edge position working with LSI
internal methodology and foundation IP development teams to support complex ASIC designs
for either external tier one customers or internal ASSP programs.
As an integral member of the customer design engineering team, the ASIC Customer Engineer
has responsibility for a wide range of tasks, including chip floor planning, place and route,
timing analysis, signal integrity, test, and design verification.
Responsible for support and completion of designs from customer provided RTL or Gate level
netlist using the latest LSI technologies.
Design completion tasks include
- Presales Support (die size support, memory generation, address customer questions and
concerns.)
- RTL Analysis & Synthesis
- Physical Design Implementation (bonding, floor planning, power structure insertion, place
and route, timing closure) using Synopsys Astro or ICC tools
- Test insertion using Mentor, LogicVision, or Virage tools
- Formal Verification (Verplex or Formality)
- Static Timing Analysis (Primetime and Primetime SI)
- Cross talk analysis
- Power verification
- DRC & LVS
Overtime, all ASIC customer engineers within the design center are expected to develop the
skills to be able to do most of the tasks described above in this role. Candidates having strong
skill sets one or more of the following areas should apply:
RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of
design implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for
complex ASIC environments. This would include strategies for power management.
or
Physical Design Implementation: The ideal candidate should be strong in either the Physical
Design which includes floor planning, design closure, & STA. Having strong DRC & LVS skills
are a plus. Strong Synopsys Astro/ICC experience a plus. Having strong Mentor Calibre skills
a plus.
4. DSP Sys Application Engineering Manager
JOB DESCRIPTION:
This position is part of a growing team supporting our latest generation of DSP solutions for
media gateway, cellular baseband, and video applications. This manager will support a team of
system applications engineers working directly with major customers to assist with porting,
integration and debugging of various software modules. Customer interaction includes both presales
activities and issue management during development phases. Ability to work well with a
variety of people and disciplines is required. Occassional travel to customer sites is expected.
Excellent communications skills in both Chinese and English are required.
Requirements
- 4 years experience as applications engineer or in product development
- Additional 2 years experience managing an engineering team
- Excellent written and verbal communications in both Chinese and English
- Embedded software development/debug experience
- General knowledge of communication technologies and protocols
Desired:
- Experience with media gateways, cellular baseband or video transcoding
- Specific experience with ARM processors and/or StarCore DSPs
- Previous interaction with major telecom vendors in China
Education
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering, Computer Science, or related disciplines
5. Preamp Analog/Mixed Signal Design Engineer
JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to
join the pre-amplifier design team. At LSI we are committed to innovation and industry
leadership. We develop advanced high-speed magneto electronic read/write IC architectures
as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for
hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through
test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
6. Preamp Analog Behavioral Modeler
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
LSI Corporation is known worldwide as a storage market leader. Our silicon-to-systems
solutions empower disk drives with the intelligence, flexibility, speed and reliability needed for
high-capacity storage across every market segment, from portable consumer electronics
devices to personal computers to enterprise-class storage systems and networks.
LSI's Storage Peripherals Division is seeking an experienced verification design engineer to
join the pre-amplifier design team. Preamp design team members define, create, modify and
verify high-speed custom integrated circuits for hard disk drive (HDD) and tape recording
products using leading edge CMOS and BiCMOS technologies.
Position Description:
- Work with a Preamp Development team to create Verilog testbench components and
simulation environment.
- Create product test plans, test cases and perform simulation and debug of Storage
Preamp mixed-signal devices.
- Must be experienced with Verilog and Verilog AMS and knowledgeable with functional
coverage methodologies.
- Ability to follow a disciplined verification methodology and work closely with a
multi-location, international design team.
- Excellent teamwork and communication skills are required.
- Preferred degree in Electrical or Electronic Engineering.
- BS required, MS or Ph.D. preferred
- The ideal candidate will have 5 years of experience as a member of a Design Verification
team responsible for implementation of a verification environment for mixed-signal
products.
- Knowledge of analog products and circuits.
- Experience with SystemVerilog, functional coverage, and assertions is highly desired
- Experience with successful tapeout of mixed-signal products from verification plan to
sign-off
- Experience with Fault Grading or Formal Verification a plus
- Strong communication skills (must be proficient in both spoken and written English)
- Able to travel internationally (to United States and throughout Asia)
- Understanding of silicon process technologies (CMOS and Bipolar) and device physics
would be a plus.
Proven analytical skills (application of math and physics to solve problems)
发表于 2010-7-30 22:09:17 | 显示全部楼层
这个公司天天招人,是不是里面员工跑光了? 还是当心点好。
 楼主| 发表于 2010-8-3 10:02:07 | 显示全部楼层
LSI上海研发中心正在扩张中,所以有很大的需求量。LSI是全资美资公司,在ASIC领域也是处于全球领先的地位。
LSI公司是创新芯片、系统和软件技术的领先供应商,采用LSI技术的产品可以使消费者与信息及数码内容之间无缝的融合。公司在众多领域提供产品和服务,包括定制和标准芯片、适配器、系统和软件。我们的产品已经获得众多世界级知名品牌的信任,为存储和网络市场提供了许多领先的解决方案。
  创新就是我们的DNA
  几十年来,LSI所倡导的先进技术定义了人们工作和生活的方式。我们的创新传统丰富源远,部分源于贝尔实验室,我们设计了众多的行业首创,包括世界上第一个数字信号处理器、SAS芯片和移动内容服务器。LSI正在创建驱动行业生态系统升级的技术。随着全球网络的数据量日益增加,共用性和互操作性要求也随之日渐增长。对行业关键标准和规范的深入与长期的参与,是我们在目标市场中获得成功的关键。这些标准和规范包括:
  Bluetooth(蓝牙)规范
  光纤通道行业协会(Fibre Channel Industry Association)
  IEEE 1394 (FireWire)和H.264标准
  SCSI商业委员会(SCSI Trade Association)
  存储网络行业协会(Storage Networking Industry Association)
  存储桥接坞工作组(Storage Bridge Bay Working Group,SBB)
  存储
  今天的客户需要强健的存储解决方案,以满足他们从手持式产品到数据中心的各种不同的要求。LSI针对该需求,提供了行业领先的产品组合,包括SAS和4 Gb/s光纤通道系统、SerDes收发器核(面向OEM存储和SAN应用)、RAID适配器、读取信道、前置放大器、电机控制器、硬盘控制器和固件。我们同时提供高集成度的和高性能的存储系统级芯片(System-on-Chip)。
  通过LSI的技术,我们的合作伙伴和客户能够获得他们需要的性能和设计灵活性,以实现杰出的存储容量、速度、可靠性和功耗效能。我们在存储的各个细分市场拥有长期的领导地位,这些市场包括:
  移动、桌面和企业级硬盘
  面向存储和SAN架构设备的定制芯片解决方案
  面向服务器的存储标准元器件和适配器
  面向大型企业集团和中型企业的模块化存储系统
  面向固定式和便携式消费电子设备的存储
  网络
  随着越来越多的人和设备与数字世界密不可分,面向家庭、企业和公共接入网络的创新网络解决方案的需求不断增加。针对这一需求,LSI提供了多种不同的解决方案组合为客户和企业提供畅通的连接服务。来自贝尔实验室的传统提供了无可比拟的网络和数据传输方面的专业经验和知识。我们为家庭、企业集团、中小型客户和公共接入网络提供始终如一的可靠服务平台。
  LSI拥有三种类别的网络产品,包括PC/连接、家庭和企业解决方案、以及服务供应商解决方案。我们生产的SoC包含亿万门集成电子晶体管和通用软件、硬件,为数字家庭、商业网络或者公共无线或有线网络提供了高质量的可靠语音、视频、数据和移动服务。
  LSI是一家全球性运作公司,总部设在美国加州Milpitas,在中国拥有上海,北京,深圳,香港等分支机构。拥有强大的产品研发,销售,市场,技术服务队伍。
LSI中国招聘博客正式落户新浪网了! http://blog.sina.com.cn/lsistaffing 我们将和广大喜爱并关注LSI的中国应聘者交流心得分享体会
GMT+8, 2025-12-22 19:19 , Processed in 0.029085 second(s), 7 queries , Gzip On, Redis On.
