查看: 2848|回复: 6
需要Senior/staff IC Verification Engineer
发表于 2010-7-28 18:03:15 | 显示全部楼层 |阅读模式
急需芯片验证方面的人才,具体的职位介绍如下:有兴趣的朋友可以联系我 susan.1817@hotmail.com
Job Purpose:
Take the lead role developing verification methodology, verification plan for SoC chips. And execute on the verification plan, achieving the best functional coverage.
Key Responsibilities:
Own multiple modules, sub-systems, create constrained random based, coverage targeted verification plan and verify them from unit level going towards chip level integration.
Own 3rd party IP verification/validation -- verify and validate them at unit, chip and system level.
Help automate verification/validation tasks, run regression, manage bug tracking, run and analyze functional and code coverage, achieve coverage goals, etc.
Support gate-level net-list functional and timing verification activities till tapeout.
Conduct pre-silicon validation on a FPGA platform.
Support test pattern generation and debugging for ATE testing.
Person Specification:
Required:
Desired:
  • Minimum 5 year of industry experience, minimum MS degree in Electrical/Computer engineering or equivalent.
  • In-depth knowledge of SoC/ASIC verification flow with emphasis in coverage driven verification/validation methodology.
  • Clear understanding of constrained random verification process, functional coverage, code coverage, assertion methodology and their philosophies.
  • Track record of picking up legacy verification environment and work on fully developed DV environment, as well as, developing DV environment from scratch.
  • In depth knowledge of ARM Instruction set and AMBA bus architecture.
  • Knowledge of C, assembly for ARM processor.
  • Intricate knowledge of Verilog, Verilog simulator and debug process.
  • Have hands-on experience on crafting complex verification environment with industry standard HVL based methodology (must have SystemC, SysVerilog, vera, or Specman-e based experience).
  • Track record of delivering multiple fully verified chips from concepts to tapeout.
  • Depth and breadth of knowledge on industry standard IO protocols: SPI, I2C, I2S, flash memories, SRAM and DRAM.
 楼主| 发表于 2010-7-29 09:27:34 | 显示全部楼层
up and up,
发表于 2010-7-29 19:17:27 | 显示全部楼层
 楼主| 发表于 2010-7-30 09:58:42 | 显示全部楼层
up and up
 楼主| 发表于 2010-8-2 09:30:40 | 显示全部楼层
up and up
 楼主| 发表于 2010-8-3 08:57:19 | 显示全部楼层
let's up it
 楼主| 发表于 2010-8-5 09:02:40 | 显示全部楼层
up and up
GMT+8, 2025-12-14 13:50 , Processed in 0.028817 second(s), 7 queries , Gzip On, Redis On.
