查看: 8552|回复: 15
[资料] 2010年5月JSSC一篇关于运放的文章
发表于 2010-7-20 23:08:56 | 显示全部楼层 |阅读模式
An Amorphous-Silicon Operational Amplifier and Its
Application to a 4-Bit Digital-to-Analog Converter
Yi-Chuan Tarn, Po-Chih Ku, Hsieh-Hung Hsieh, and Liang-Hung Lu
Abstract—A circuit topology suitable for the implementation of
operational amplifiers (OPAMPs) in an amorphous-silicon (a-Si)
thin-film-transistor (TFT) technology is presented in this paper.
Due to the use of a positive feedback in the input differential pair,
the gain of the OPAMP is effectively boosted, facilitating analog
circuit designs for system-on-panel (SoP) applications. Based on
the proposed technique, a 4-bit digital-to-analog converter (DAC)
prototype, which consists of a resistor string and a unity-gain
buffer, is developed. The DAC is implemented by using an 8- m
a-Si NTFT process. Operated at a supply voltage of 25 V, the
fabricated circuit consumes a dc power of 3.68 mW. For an output
voltage range from 9.5 to 12.5 V, the measurement results indicate
a differential non-linearity (DNL) of 0.216 LSB and an integral
non-linearity (INL) of 0.667 LSB. With a settling time less than
1.1 ms, the DAC circuit can operate at a maximum conversion rate
of 0.9 kS/s.
Index Terms—Amorphous silicon (a-Si), digital-to-analog converters
(DACs), operational amplifiers (OPAMPs), positive feedback,
resistor string, thin-film transistors, unity-gain buffer.
An Amorphous-Silicon Operational Amplifier and Its.pdf
878.08 KB, 下载次数: 178 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-7-20 23:17:07 | 显示全部楼层
谢谢了!
发表于 2010-7-21 08:09:48 | 显示全部楼层
看看 谢谢
发表于 2010-7-21 09:16:30 | 显示全部楼层
看看,多谢
发表于 2010-7-21 09:37:09 | 显示全部楼层
顶起~~~~~~~~~~~~~~~~~
发表于 2011-10-31 00:13:44 | 显示全部楼层
谢谢楼主!
发表于 2011-11-10 21:10:25 | 显示全部楼层
谢谢分享了
发表于 2011-11-22 16:27:38 | 显示全部楼层
回复 1# 致橡树
    xiexiele ,zhenghao xuyao
发表于 2011-11-22 16:30:51 | 显示全部楼层
好东西!!!!!
发表于 2012-8-7 15:37:48 | 显示全部楼层
多谢分享(什么时候才能上JSSC去灌灌水啊,感叹。。)
GMT+8, 2025-12-16 07:52 , Processed in 0.024382 second(s), 5 queries , Gzip On, Redis On.
