查看: 7468|回复: 16
questasim in LINUX
发表于 2010-7-14 16:30:24 | 显示全部楼层 |阅读模式
hello everyone...
I have a question that about my linux environment..
I install the questasim in my linux-OS pc  after set all environment value
and license.dat file ,  then restart my pc ...
after pc restart, I type 'vsim' in terminal  and the gui can work in normally
but I find a question that is I can't type any things, any works, in command
window
did any one can tell me what's goings on ?
or any one had meet this problem before ?
is this problem happend from license.dat ?
THX U
发表于 2010-7-14 17:48:27 | 显示全部楼层
have you any message(s) in terminal after type 'vsim'?
how you install Questasim?
which linux you use?
发表于 2010-7-14 22:52:10 | 显示全部楼层
Do you have license?
发表于 2010-7-14 23:46:08 | 显示全部楼层
Yes, of course
 楼主| 发表于 2010-7-15 09:58:15 | 显示全部楼层
TO crayfish :
1. after type 'vsim' ->  the GUI open in normally and I can use all button, it
                                 seems likes the license is OK, so the terminal did not
                                 show any wrong message.
2. I install Questasim in linux 'red hat enterprise 4' by 'questasim-linux.exe'
3. 'red hat enterprise 4'
my problem is about the GUI which can open normally but can't  type command in "transcript" window.  all the button on the GUI can be use.  Just the "transcript" window can't type any word..
THANK U
发表于 2010-7-15 12:12:36 | 显示全部楼层
Very strange situation. Usually, or do not start 'vsim' or ended when you try to simulate the project (when license problem).
Can you run script from GUI menu? 'Tools-Tcl->Execute Macro...'
 楼主| 发表于 2010-7-15 22:22:57 | 显示全部楼层
to crayfish :
1. It's seems strange problem, I have try to fine somethings over google
    wed. some people had meet this problem before but I didn't found any
    answer to fix.
    Maybe someone who know what's somethigns wrong....
2. when I open the GUI like you says use the button
    Of course. It's can run in normally, I can compile VHDL, Verylog language
    and  create "lib"  by  script file .  so  now I try to use questasim by scripts
3. Today I find a question that is my script use the 'vsim' command to do
    simulation there have a problem :
a.  ' faild to novas.dll '  do you know where I can find the novas.dll ?
     (over debussy(verdi)  project file ?)
b.   and have you ever use questasim to dumpfile  'fsdb' ?
c.   if  you know how to do that could you support me the script or
      infomation
thank you very much
发表于 2010-7-18 08:50:19 | 显示全部楼层
It seems that ur script should be used under win.
I think in ur script, you should add verdi path under linux.
发表于 2010-7-18 08:53:01 | 显示全部楼层
BTW, can you share the license crack for questa in linux?
I wanta install questa6.5d under centos,but I have not find any license......
发表于 2010-11-14 07:36:03 | 显示全部楼层
GMT+8, 2025-12-25 03:00 , Processed in 0.021961 second(s), 6 queries , Gzip On, Redis On.
