楼主: arhqu
calibre_2010_2_13 for linux
发表于 2010-8-17 19:37:51 | 显示全部楼层
发表于 2010-8-17 20:45:45 | 显示全部楼层
thanks
发表于 2010-8-18 20:30:30 | 显示全部楼层
thanks !!!
发表于 2010-8-29 13:56:27 | 显示全部楼层
好像沒有安裝成功的回應冽....樓主是否可以解決一下之前的問題啊...不然真的不敢下載冽..
发表于 2010-8-29 17:06:50 | 显示全部楼层
感谢楼主分享
发表于 2010-8-29 18:32:45 | 显示全部楼层
发表于 2010-8-29 19:21:29 | 显示全部楼层
发表于 2010-9-1 14:26:51 | 显示全部楼层
安装后,报错,不能用。请朋友说明一下,怎么解决,谢谢啦!
Installation in progress ... Please Wait
0%--10%--20%--30%--40%--50%--60%--70%--80%--90%--100%
||||||||||||||||||||java.util.zip.ZipException: invalid literal/length code
        at java.util.zip.InflaterInputStream.read(Unknown Source)
        at java.util.zip.ZipInputStream.read(Unknown Source)
        at java.util.zip.ZipInputStream.closeEntry(Unknown Source)
        at java.util.zip.ZipInputStream.getNextEntry(Unknown Source)
        at com.mentor.install.controlpanel.engine.Engine.installCompressedEntities(Engine.java:1532)
        at com.mentor.install.controlpanel.engine.Engine.installPackage(Engine.java:869)
        at com.mentor.install.controlpanel.engine.Engine.installMedia(Engine.java:721)
        at com.mentor.install.controlpanel.engine.Engine.changeTarget(Engine.java:681)
        at com.mentor.install.controlpanel.engine.Engine.installProductMsgSent(Engine.java:303)
        at com.mentor.install.controlpanel.messaging.CPMessageBroker.sendMessage(CPMessageBroker.java:373)
        at com.mentor.install.controlpanel.gui.IPWInstallStatusCA.installProducts(IPWInstallStatusCA.java:142)
        at com.mentor.install.controlpanel.gui.ProductsPageArea.doNextSelected(ProductsPageArea.java:727)
        at com.mentor.install.controlpanel.gui.ProductsPageArea.automaticResponseProvider(ProductsPageArea.java:402)
        at com.mentor.install.controlpanel.gui.ProductsPageArea.driveQuickBatch(ProductsPageArea.java:409)
        at com.mentor.install.controlpanel.gui.ProductsPageArea.startInstallProducts(ProductsPageArea.java:263)
        at com.mentor.install.controlpanel.gui.AppArea.quickInstallProducts(AppArea.java:465)
        at com.mentor.install.controlpanel.gui.InstallGUI.runQuick(InstallGUI.java:387)
        at com.mentor.install.controlpanel.Install.startInstall(Install.java:571)
        at com.mentor.install.controlpanel.Install.main(Install.java:2726)
Installation Completed with Errors.
INFORMATION ONLY:
    Message: End of Installation. The products were installed at /soft
发表于 2010-9-1 14:37:28 | 显示全部楼层
ixl_cal_2010.2_13.12/shared/pkgs/icv_oa.ixl/2.2.6/include/oaLefDef/oaLefDefInOptions.h
        ixl_cal_2010.2_13.12/shared/pkgs/icv.ixl/examples/calibre_CFA_pkg/dfmdb/revisions/1/93_layer.anno
        ixl_cal_2010.2_13.12/shared/pkgs/icv.ixl/systest_data/calibre.db/perc_ldl/cd/rules
        ixl_cal_2010.2_13.12/pkgs/mgc_doc_utils.ixl/olh_perl/_lib/unicode/Is/BidiR.pl
        ixl_cal_2010.2_13.12/shared/pkgs/icv_oa.ixl/2.2.6/lib/linux_rhel30_32.bkup/opt/temp/liboaPcellCPP.so
        ixl_cal_2010.2_13.12/shared/pkgs/icv.ixl/examples/calibre_CFA_pkg/dfmdb/revisions/1/28.layer
        ixl_cal_2010.2_13.12/pkgs/icxc.ixl/model_lib/models/C/model_7/lib/mcs2d/dndt.eqn.tmpl
        ixl_cal_2010.2_13.12/shared/pkgs/icv.ixl/systest/test.Calibreinteractive
        ixl_cal_2010.2_13.12/shared/pkgs/icv_oa.ixl/2.2.6/lib/linux_rhel21_32/opt/liboaCommon.so
        ixl_cal_2010.2_13.12/pkgs/icv_comp.ixl/8.4/lib/Tix8.4/library/bitmaps/ck_def.xbm
        ixl_cal_2010.2_13.12/pkgs/mgc_doc_utils.ixl/olh_perl/_lib/unicode/Is/P.pl
        ixl_cal_2010.2_13.12/pkgs/icv_hier_widgets.ixl/lib/widgets/ui_menus.tcl
        ixl_cal_2010.2_13.12/pkgs/icv_comp.ixl/8.4/lib/tile0.8.2/pkgIndex.tcl
        ixl_cal_2010.2_13.12/shared/pkgs/icv_oa.ixl/2.2.6/bin/linux_rhel30_64/opt/oaDataCompatibilityTest
        ixl_cal_2010.2_13.12/pkgs/icwb.ixl/pvt/tcl/cwbViewDepthDialog.itcl
        ixl_cal_2010.2_13.12/pkgs/icv_comp.ixl/8.4/lib/tktreectrl-2.2.9/demos/pics/help-page.gif
        ixl_cal_2010.2_13.12/pkgs/icv_comp.ixl/8.4/lib/tk/demos/clrpick.tcl
    Detail:  The error occurred in the ixl.1273787655 package.  The installation will continue, but the products that rely on these file(s) may not work properly.
Installation Completed! Installed to: /soft/mentor
INFORMATION ONLY:
    Message: End of Installation. The products were installed at /soft/mentor
发表于 2010-9-7 16:26:23 | 显示全部楼层
真的不能安装吗?
GMT+8, 2025-12-25 00:22 , Processed in 0.018196 second(s), 3 queries , Gzip On, Redis On.
