A variable gain amplifier architecture suitable for foundry CMOS is constructed using linearized transconductance blocks. The use of a four-transistor transconductance cell allows for wider gain range and larger signal swing under low supply conditions than the simple differential pair used in previous work. Experimental results with 0.6 um CMOS show -5 to 35 dB gain and 20 MHz bandwidth at 21 mW.
