查看: 8234|回复: 26
[Paper]A Low-Voltage Low-Power Wide-Range CMOS Variable Gain Amplifier
发表于 2006-9-14 21:22:39 | 显示全部楼层 |阅读模式
Abstract—In this paper, a compact low-power (LP) low-voltage (LV) metal–oxide–semiconductor-only (MOS-only) variable gain amplifier (VGA) is introduced. This amplifier based on complementary MOS (CMOS) transistors operating in strong inversion is composed of a pseudo-exponential current-to-voltage converter, analog multiplier, and output stage. The gain of the amplifier is controlled exponentially by a novel wide-range pseudoexponential current-to-voltage converter implemented with two back-to-back connected current mirrors exhibiting superb exponential characteristic. Also, a new LV/LP composite transistor is introduced to increase the input dynamic range of the multiplier. The amplifier is fabricated using a 2-m MOSIS n-well process, and its simulation and measurement results are shown in detail.
A Low-Voltage Low-Power Wide-Range CMOS Variable Gain Amplifier.pdf
396.96 KB, 下载次数: 159 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-15 01:14:57 | 显示全部楼层
再顶一下
发表于 2006-11-10 19:29:31 | 显示全部楼层
支持一个!!
发表于 2007-11-18 11:38:44 | 显示全部楼层
thanks
发表于 2007-11-18 17:09:16 | 显示全部楼层
柯明道ESD简洁版
发表于 2008-3-5 12:48:46 | 显示全部楼层
看看再说.
发表于 2008-3-5 13:25:40 | 显示全部楼层
ding thanks
发表于 2008-3-8 14:57:21 | 显示全部楼层
看看吧
发表于 2008-7-9 14:48:45 | 显示全部楼层
thanks
thanks
发表于 2008-7-9 14:51:00 | 显示全部楼层
thanks
GMT+8, 2025-12-23 10:50 , Processed in 0.026557 second(s), 6 queries , Gzip On, Redis On.
