楼主: gman
crack::Tanner 15 (Just released)
发表于 2010-7-24 22:55:58 | 显示全部楼层
明白了,这个破解是针对15.0的,而论坛中的下载链接是15.01,而15.01的S-EDIT和W-EDIT做了改进,所以这两个是不行的,EVI也不行。所以还是盼着高人推出彻底的破解之后再说吧,哎!现在只有暂时用着Tanner 14.11了,不过已经可以了。还有楼主怎么忙到没有时间上传15.0安装文件?
发表于 2010-7-25 00:53:19 | 显示全部楼层
Thanks a lot !!!!!!!
发表于 2010-7-25 00:54:24 | 显示全部楼层
Thanks again !!!!!!!!!!!
发表于 2010-7-25 00:56:44 | 显示全部楼层
发表于 2010-7-25 00:57:51 | 显示全部楼层
Thanks a lot !!!!!!
发表于 2010-7-25 00:59:02 | 显示全部楼层
 楼主| 发表于 2010-7-25 01:32:08 | 显示全部楼层
51# stevenwyh
Dear stevenwyn,
The work 'busy' means a lot... when you will be in my position you will know what it is called 'busy'. so dont persist on me.
发表于 2010-7-25 07:29:28 | 显示全部楼层
Do u have rapidshare link ?
发表于 2010-7-25 07:30:47 | 显示全部楼层
发表于 2010-7-25 07:32:21 | 显示全部楼层
Thx.!!!!!!!!!!!!
GMT+8, 2025-12-29 04:41 , Processed in 0.017156 second(s), 3 queries , Gzip On, Redis On.
