查看: 8501|回复: 2
[求助] 安装rvct2.2出现问题
发表于 2010-6-3 09:24:21 | 显示全部楼层 |阅读模式
在安装到最后的时候出现问题,
Error: %variable HOSTPLAT is not defined in File RDI\armsd\1.3.1\66\install.xml
请问这个如何解决
 楼主| 发表于 2010-6-3 09:41:55 | 显示全部楼层
Error: Launching the ARM Installer has failed
This ARM Product does not contain an installer. It instead relies on finding
one on your computer from a previously installed product.
The ARMROOT environment variable which helps locate this installer is not set.
Please either
   A) (re)install a suitable ARM product
or
   B) manually set your ARMROOT environment variable to the full path of the dir
ectory containing your previous ARM product.
failed to find cleanup.exe
Press space to close this window
发表于 2010-6-4 23:43:13 | 显示全部楼层
thanks
it is great
GMT+8, 2025-12-23 20:30 , Processed in 0.020442 second(s), 5 queries , Gzip On, Redis On.
