查看: 28506|回复: 84
[原创] 发书Introduction to Microelectronic Fabrication
发表于 2010-5-31 00:31:17 | 显示全部楼层 |阅读模式
Introduction to Microelectronic Fabrication: Volume 5 of Modular Series on Solid State Devices (2nd Edition)
找了好久啊。。。。
Jaeger - Vol.V Introduction to Microelectronic Fabrication 2ed.rar
4.22 MB, 下载次数: 1089 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2010-5-31 01:30:19 | 显示全部楼层
Product Description
For courses in Theory and Fabrication of Integrated Circuits. The author's goal in writing this text was to present a concise survey of the most up-to-date techniques in the field. It is devoted exclusively to processing, and is highlighted by careful explanations, clear, simple language, and numerous fully-solved example problems. This work assumes a minimal knowledge of integrated circuits and of terminal behavior of electronic components such as resistors, diodes, and MOS and bipolar transistors.
From the Back Cover
Introduction to Microelectronic Fabrication, Second Edition, by Richard C. Jaeger, is a concise survey of the most up-to-date techniques in the field. It is devoted exclusively to processing and is highlighted by careful explanations, clean, simple language, and numerous fully solved example problems.
The second edition includes an entirely new chapter on MEMS, as well as substantial modifications to the chapters on MOS and bipolar process integration. Also included is new or expanded coverage of lithography and exposure systems, trench isolation, chemical mechanical polishing, shallow junctions, transient enhanced diffusion, copper Damascene processes and process simulation.
发表于 2010-5-31 14:33:16 | 显示全部楼层
thanks
发表于 2010-5-31 14:52:23 | 显示全部楼层
3xshairng
发表于 2010-6-2 15:17:45 | 显示全部楼层
gooooooooooooooooood
发表于 2010-7-19 14:55:32 | 显示全部楼层
RE: 发书Introduction to Microelectronic Fabrication
谢谢楼主!
发表于 2010-7-22 04:14:57 | 显示全部楼层
good book
发表于 2010-7-22 06:29:38 | 显示全部楼层
TKSTKS
发表于 2010-7-22 08:07:16 | 显示全部楼层
工艺啊?
下来看看
发表于 2010-7-22 18:51:20 | 显示全部楼层
thanks
GMT+8, 2025-12-18 05:41 , Processed in 0.025142 second(s), 9 queries , Gzip On, Redis On.
