查看: 12812|回复: 25
[求助] 帮忙下IEEE文章 A Novel Three-Phase Buck Converter with Bootstrap Driver Circuit
发表于 2010-5-28 20:19:10 | 显示全部楼层 |阅读模式
A Novel Three-Phase Buck Converter with Bootstrap Driver Circuit Abe, K.; Nishijima, K.; Harada, K.; Nakano, T.; Nabeshima, T.; Sato, T.;
Power Electronics Specialists Conference, 2007. PESC 2007. IEEE
Digital Object Identifier: 10.1109/PESC.2007.4342286
Publication Year: 2007 , Page(s): 1864 - 1871
IEEE Conferences
Abstract
Full Text: PDF (915 KB)
Analysis and design consideration of the novel three phase converter with new bootstrap driver circuit for the mobile micro processor in the laptop PC are presented. The voltage conversion ratio of the proposed converter is one third of the duty cycle. The voltage across the switches during switching operation is one-third of the input source voltage. The current ripple of the output smoothing capacitor is the same as that of conventional five-phase buck converter. The current balance of the respective phases is automatically achieved without any current sensing means. The above fine characteristics are simply achieved with two additional capacitors. Read More?
发表于 2010-5-28 20:38:43 | 显示全部楼层
1# ampper
我承认,因为你发了太多贴了,所以很烦,就给你下了,呵呵
A Novel Three-Phase Buck Converter with Bootstrap Driver Circuit..pdf
917.89 KB, 下载次数: 229 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-5-28 20:52:09 | 显示全部楼层
我承认,你人太好了,所以非常感谢!
2# tiankuang25
发表于 2010-5-28 22:01:51 | 显示全部楼层
这篇文章还不错
发表于 2010-5-30 13:33:47 | 显示全部楼层
kankan
发表于 2010-5-31 08:44:24 | 显示全部楼层
想學習一下,謝謝。
发表于 2010-5-31 09:03:01 | 显示全部楼层
呵呵,看看那
发表于 2010-6-29 13:48:50 | 显示全部楼层
Thank you !!  还有没有关于DC convter the paper 可以hshare 一下的! 非常感谢!!
发表于 2010-7-29 01:09:06 | 显示全部楼层
感謝分享
发表于 2010-10-27 10:10:54 | 显示全部楼层
jjjjjjjjjjjjjjjjjjjjj
GMT+8, 2025-12-28 22:37 , Processed in 0.025052 second(s), 6 queries , Gzip On, Redis On.
