查看: 15194|回复: 54
[资料] 清晰版High Performance ASIC Design: ebook, pdf 1个包
发表于 2010-5-16 16:42:00 | 显示全部楼层 |阅读模式
High Performance ASIC Design: Using Synthesizable Domino Logic in an ASIC Flow
http://www.amazon.com/High-Performance-ASIC-Design-Synthesizable/dp/0521873347/ref=sr_1_1?ie=UTF8&s=books&qid=1273999479&sr=1-1
Publisher: Cambridge University Press | 2008-09-15 | ISBN: 0521873347 | PDF |
Presenting a methodology for using domino logic in an ASIC design flow developed over several years in an industrial context, this text covers practical issues related to the use of domino logic in an automated framework, and brings together all the knowledge needed to apply these design techniques in practice. Beginning with a discussion of how to achieve high speed in ASIC designs, subsequent chapters detail the design and characterization of standard cell compatible domino logic libraries and an advanced domino logic synthesis flow.
Contents
1 An introduction to domino logic 1
   1.1 CMOS and NMOS 1
   1.2 Domino logic circuits 5
   1.3 Clocking domino logic 12
   1.4 Summary 15
2 High-speed digital design 18
   2.1 Microprocessors since 1989 18
   2.2 Microarchitectures for high speed 22
   2.3 Designing and using high-speed memories 31
   2.4 What to remember if applying domino logic 35
3 Domino logic library design 37
   3.1 High-speed digital circuit design 37
   3.2 An introduction to standard cells 42
   3.3 Designing a high-performance standard cell library 45
   3.4 Circuit design of domino logic cells: a qualitative approach 48
   3.5 Circuit design of domino logic cells: a quantitative approach 51
   3.6 Characterizing domino logic-compatible registers 63
   3.7 Layout of domino logic standard cells 65
   3.8 Timing models for domino logic cells 66
4 Domino logic synthesis 70
   4.1 Introduction to domino logic synthesis 70
   4.2 Unate transform 73
   4.3 Phase assignment 75
   4.4 Phase-assignment rules 77
   4.5 An example domino synthesis flow 86
   4.6 Schematic capture of domino designs 106
5 Circuits designed with domino logic in an ASIC flow 108
   5.1 Introduction 108
   5.2 Domino integer execution unit 108
   5.3 A synthesized domino logic DSP core 119
   5.4 A synthesizable domino logic Viterbi add–compare–select (ACS) test chip 121
   5.5 Intel’s published domino logic synthesis flow 124
   5.6 Conclusions 126
6 Evolution of domino logic synthesis 127
   6.1 The state of digital ASIC design methodologies 127
   6.2 Process trends and domino logic 128
   6.3 Clocking methodology for domino circuits 130
   6.4 Synthesizing other dynamic logic families 132
   6.5 Flow improvements for domino synthesis 137
   6.6 The case for domino logic synthesis 141
Index
High Performance ASIC Design.rar
2.36 MB, 下载次数: 693 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-5-16 17:05:23 | 显示全部楼层
asdsadf
发表于 2010-5-16 17:43:53 | 显示全部楼层
好东东……
发表于 2010-5-17 08:35:14 | 显示全部楼层
下来看看,谢谢。
发表于 2010-5-17 19:57:36 | 显示全部楼层
thanks
发表于 2010-7-12 17:52:16 | 显示全部楼层
清晰版,期待。谢谢分享。
发表于 2010-7-12 17:57:26 | 显示全部楼层
这个不能打开,包本身没有问题,可能文件有问题。
发表于 2010-7-12 18:06:32 | 显示全部楼层
对不起,可能是我机器的问题。文件应该是好的。
发表于 2010-7-13 14:08:56 | 显示全部楼层
顶顶!
发表于 2010-11-17 09:08:08 | 显示全部楼层
谢谢楼主分享
GMT+8, 2025-9-18 04:14 , Processed in 0.024024 second(s), 7 queries , Gzip On, Redis On.
