查看: 3298|回复: 5
上海IC公司内部推荐
发表于 2010-5-12 13:13:28 | 显示全部楼层 |阅读模式
Atheros
验证人员
工作2-5年都可以,
最好有specman,vera或者vmm相关经验
设计人员也有招聘。
email:albert_lei@yeah.net
发表于 2010-5-12 14:47:08 | 显示全部楼层
谢谢发布~~
发表于 2010-5-13 08:29:26 | 显示全部楼层
请问,是哪个方面的设计人员在招聘??、
 楼主| 发表于 2010-5-13 12:31:55 | 显示全部楼层
ASIC Design Engineer . Shanghai
QUALIFICATION (DETAIL):
Education:
 BS in Electrical/Electronics Engineering, MS preferred.
Experience:
 .. 3 years experience with Verilog programming, logic synthesis and gate
timing. A proven record of delivering successful ASIC's to the market is
preferred.
 .. One or more advantages as following are highly desirable: A strong
background in digital communication, signal processing and networking
protocols; IC Design experiences in wireless communications and audio
processing; Experiences with ARM/DSP, AHB bus and External interface
development.
 .. Good communication skills in English.
 .. Experience in Bluetooth chip design a plus
 .. Must be proficient in RTL coding, logic synthesis, gate-level simulations.
 .. Good knowledge of IC design backend flows.
 .. Experiences in IC life-cycle from conception, design, verification,
top-level netlist with pads to tape-out, chip-testing and mass-production.
 .. FPGA, PCB or embedded SW skill is a plus.
DESCRIPTION OF FUNCTION & RESPONSIBILITY:
The Digital Design Engineer will be responsible for designing our wireless and
SOC ASIC's. You will work closely with our architecture/algorithm engineers to
explore ideas for next generation products and then develop RTL to tern these
ideas into customer solutions.
 .. Chip features specification and RTL design
 .. Synthesis, verification, timing.
 .. FPGA emulation, lab validation and debugging.
 楼主| 发表于 2010-5-13 12:34:07 | 显示全部楼层
Digital Design Verification Engineer
 Develop reusable block-level and system-level ASIC testbenches using
Systemverilog
 Develop new ASIC verification environments to support ASIC
development.
 Maintain existing ASIC verification environments.
 Define and develop application tests required to verify Asics meet
functional and performance goals.
 Define and implement functional/code coverage plans.
 Develop testing and regression methodologies for new verification flow.
 Develop/maintain/enhance environment tools/scripts/makefiles.
EDUCATION:
Master's degree from first rate engineering schools is preferred.
EXPERIENCE:
 Minimum of 3 years ASIC Verification experience in a product
development environment
 Proven ASIC Design Verification skills
 Rich experience with Specman or System Verilog
 Digital verification experience on MIPS CPU/AXI/DDR Controller
 Knowledge of data and telecommunication networking(IP/Ethernet)
 Experience with one or more scripting languages: TCL, Perl, python
 Superior debugging skills for large ASIC designs
 Strong written and verbal communication skills
 Adaptable to evolving customer requirement
发表于 2011-1-16 11:21:23 | 显示全部楼层
帮你顶下啊
GMT+8, 2025-12-22 09:41 , Processed in 0.025847 second(s), 7 queries , Gzip On, Redis On.
