查看: 15634|回复: 20
Laker安装完后,启动问题!
发表于 2010-5-1 15:46:26 | 显示全部楼层 |阅读模式
Laker version--->32v4p3
Laker 32v4p3 install path--->/ecad/laker_32v4p3_linux
.bashrc---->
#laker config ENV
#study /laker/demo/config/CSHRC
export SICANVAS=/ecad/laker_32v4p3_linux
export LAKER_LICENSE=$SICANVAS/license/license_32v4.dat  #add by dsjin for laker license
#export LAKER_LICENSE=5219@spc3233
#export LAKER_LICENSE=27000@localhost.localdomain
#export LAKER_LICENSE=27000@`hostname`
export SC_LICENSE_FILE=27000@`hostname`
#set path=(${LAKER}/bin $path)
export PATH=$SICANVAS/binPATH
alias lic_start='$SICANVAS/bin/lmgrd     -c $LAKER_LICENSE -l /tmp/LAKER.log'
alias  lic_down='$SICANVAS/bin/lmdown    -c $LAKER_LICENSE'
alias lic_check='$SICANVAS/bin/lmstat -a -c $LAKER_LICENSE'
alias  lic_read='$SICANVAS/bin/lmreread  -c $LAKER_LICENSE'
#alias lic_start='$SICANVAS/bin/lmgrd     -c $SC_LICENSE_FILE -l /tmp/LAKER.log'
#alias  lic_down='$SICANVAS/bin/lmdown    -c $SC_LICENSE_FILE'
#alias lic_check='$SICANVAS/bin/lmstat -a -c $SC_LICENSE_FILE'
#alias  lic_read='$SICANVAS/bin/lmreread  -c $SC_LICENSE_FILE'
#limit coredumpsize 0k
#limit descriptors unlimited
#limit filesize unlimited
[root@localhost:~] lic_check
lmstat - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
Flexible License Manager status on Sat 5/1/2010 03:47
License server status: 27000@localhost.localdomain
    License file(s) on localhost.localdomain: /ecad/laker_32v4p3_linux/license/license_32v4.dat:
localhost.localdomain: license server UP (MASTER) v11.6
Vendor daemon status (on localhost.localdomain):
   sclmgrd: The desired vendor daemon is down. (-97,121)
[root@localhost:~] laker
logDir = /root/lakerLog
Open default display file = /ecad/laker_32v4p3_linux/etc/default.dsp
Laker - Toward Custom Layout Automation, Release 3.2v4p3 32-bit (Linux) 07/31/2009
Copyright (C) 1999 - 2009 by SpringSoft, Inc.
Display :0.0 ==> Current mode : TrueColor
   The PseudoColor mode is not available under current setting. Switch to use TrueColor mode.
   *** Limitation: Blinking is not supported under TrueColor mode.
fontPath(SPS_FONT_PATH) = /ecad/laker_32v4p3_linux/TTFont
*ERROR* License checking failed, or the maximum number of licensed users has been reached! Use laker -licdebug for more information.
[root@localhost:~]
license file---------->
#Laker 32v4 license
#SERVER localhost.localdomain HOSTNAME=localhost.localdomain 27000
#DAEMON sclmgrd /home/EDA/Novas/platform/LINUX/bin/sclmgrd
SERVER localhost.localdomain 000c290ff713 27000
DAEMON sclmgrd /ecad/laker_32v4p3_linux/bin/sclmgrd
# Novas (Silicon Canvas) "Laker" License File
FEATURE Laker_Viewer sclmgrd 6.000 01-jan-2014 99 28B663031F05A1A3 \
VENDOR_STRING=ES=NLFBMKCOLCPGJQGMFHEN START=1-jun-2003 SIGN=A3E859AADED4EEE8
FEATURE Laker_L2 sclmgrd 6.000 01-jan-2014 99 A54EEACFD366590E \
VENDOR_STRING=ES=FPHBIGBHCCEQDLCFHIKN START=1-jun-2003 SIGN=0CF0A3C8ECB21310
FEATURE Laker_L3 sclmgrd 6.000 01-jan-2014 99 DF3D24D68866E256 \
VENDOR_STRING=ES=FPBDLKNCGKJQMIBDQNKF START=1-jun-2003 SIGN=9B4C560A7F042EEA
FEATURE Laker_T1 sclmgrd 6.000 01-jan-2014 99 9E6CBEFAB0814225 \
VENDOR_STRING=ES=GNMGGKKPCMGOIHNICFGC START=1-jun-2003 SIGN=F58E978215546F82
FEATURE Laker_L1 sclmgrd 6.000 01-jan-2014 99 34F4C632FEE49377 \
VENDOR_STRING=ES=PQHINEELCKCIOBLOONDN START=1-jun-2003 SIGN=F6DAAE7A2D306826
FEATURE Laker_L0 sclmgrd 6.000 01-jan-2014 99 1C9604BA3451083D \
VENDOR_STRING=ES=FIBNODOGFFLHOGOEIQCK START=1-jun-2003 SIGN=6A0E3340CFD8C7E6
FEATURE Laker_iDRC sclmgrd 6.000 01-jan-2014 99 9AB6203641C612CF \
VENDOR_STRING=ES=NFQQOONIKPJQOFFKJJEK START=1-jun-2003 SIGN=90F4B210F6B8D3DE
FEATURE Laker_iLVS sclmgrd 6.000 01-jan-2014 99 6046AAA0EDAC6E6F \
VENDOR_STRING=ES=KOEDQNIPJBKONKHQEBJE START=1-jun-2003 SIGN=C874AE2227068A22
FEATURE Laker_T1_LE sclmgrd 6.000 01-jan-2014 99 09FCF1C1E26EEBDA \
VENDOR_STRING=ES=MLBHQNJBOQMPMDEFIQCB START=1-jun-2003 SIGN=8B166A4A9D547820
FEATURE LEO_Authoring sclmgrd 6.000 01-jan-2014 99 6CB4B2AB495D2669 \
VENDOR_STRING=ES=FPPFEKDMGIGOLNDKDGDB START=1-jun-2003 SIGN=8C9C9190766EB680
FEATURE LEO_DRC sclmgrd 6.000 01-jan-2014 99 7278C77C1B614B90 VENDOR_STRING=ES=JJOLGMEIGMKGPEHCEKGB \
START=1-jun-2003 SIGN=057AD9687F100D50
FEATURE LEO_DRCERC sclmgrd 6.000 01-jan-2014 99 55D3C82C1823206D \
VENDOR_STRING=ES=GBPNLBPOJHHJDCKBLQEF START=1-jun-2003 SIGN=3CDE985E5804E7B8
FEATURE LEO_LAYOUT sclmgrd 6.000 01-jan-2014 99 D85D964964A518B3 \
VENDOR_STRING=ES=GQPNOBIBHNJMLHBHKQEE START=1-jun-2003 SIGN=92D4CB0C449C63B0
FEATURE LEO_Navigator sclmgrd 6.000 01-jan-2014 99 D108EAF8883439D0 \
VENDOR_STRING=ES=QKIBNKONNGBHFOGEQGHB START=1-jun-2003 SIGN=A9D4623A5AF64DF0
FEATURE LEO sclmgrd 6.000 01-jan-2014 99 6BC463A537631CD1 VENDOR_STRING=ES=NHKENBIMCQEMEMBHEQFF \
START=1-jun-2003 SIGN=42DAB784058292C8
FEATURE LEO_Builder sclmgrd 6.000 01-jan-2014 99 CD5A7D052B9F2867 \
VENDOR_STRING=ES=DDIDGKIJPDIOGHIHBKBI START=1-jun-2003 SIGN=EC209FB4A8F6CCF
 楼主| 发表于 2010-5-1 15:48:55 | 显示全部楼层
系统信息如下:
[root@localhost:~] uname -a
Linux localhost.localdomain 2.6.9-89.EL #1 Mon Apr 20 10:22:29 EDT 2009 x86_64 x86_64 x86_64 GNU/Linux
[root@localhost:~] cat /etc/issue
issue      issue.net
Red Hat Enterprise Linux AS release 4 (Nahant Update 8)
Kernel \r on an \m
[root@localhost:~] cat /proc/version
Linux version 2.6.9-89.EL (mockbuild@hs20-bc2-5.build.redhat.com) (gcc version 3.4.6 20060404 (Red Hat 3.4.6-11)) #1 Mon Apr 20 10:22:29 EDT 2009
[root@localhost:~]
错误信息如下:
[root@localhost:~]
发表于 2010-5-17 13:48:43 | 显示全部楼层
支持楼主,非常感谢。
发表于 2010-5-17 13:54:59 | 显示全部楼层
支持楼主,非常感谢。
发表于 2010-5-17 14:23:47 | 显示全部楼层
好东西,正在找,感谢分享
发表于 2010-5-17 15:34:13 | 显示全部楼层
好东西,正在找
发表于 2010-6-22 14:14:12 | 显示全部楼层
没看懂  麻烦楼主写清楚点啊
发表于 2010-6-22 14:26:59 | 显示全部楼层
license error  !!!!!!
头像被屏蔽
发表于 2010-6-24 01:23:39 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-9-27 22:26:57 | 显示全部楼层
感謝!
感謝!
感謝!
個人用心求進步.
國家能力向前行!
GMT+8, 2025-12-3 23:51 , Processed in 0.019321 second(s), 5 queries , Gzip On, Redis On.
