查看: 5879|回复: 22
[原创] Proteus Professional V7.6 SP4 is now cracked
发表于 2010-4-27 01:30:33 | 显示全部楼层 |阅读模式
Download Link
There as been no new release for Proteus 7.6sp4, the Released files are
1. Proteus 7.6 SP4 Link : http://rapidshare.com/files/337924325/76SP4.rar.html - Install Proteus
 楼主| 发表于 2010-4-27 01:32:06 | 显示全部楼层
 楼主| 发表于 2010-4-27 01:33:59 | 显示全部楼层
3. due to error in patched files you need this http://rapidshare.com/files/341584733/fix.rar - 1st update
 楼主| 发表于 2010-4-27 01:35:04 | 显示全部楼层
4. To fix error with PWM replace pic16.dll with http://rapidshare.com/files/360728086/pic16.DLL - 2nd update
 楼主| 发表于 2010-4-27 01:36:57 | 显示全部楼层
Note: Important you follow these Rules
1- For windows Vista and Seven users do not forget to run the patch as administrator (Right Click->Run As Administrator)
 楼主| 发表于 2010-4-27 01:38:21 | 显示全部楼层
2- Do not reply with any "ISIS Crash" message until you know the cause, this will be easier to trace.
 楼主| 发表于 2010-4-27 01:40:31 | 显示全部楼层
NOTES :
1. Uninstall old versions of proteus first.
2. Delete the program folder labcenter manually (Labcenter Electronics folder)
3. Run proteus 7.1 sp2 setup file
4. Remove old Proteus license (if exists)
5. Point to the new LICENCE.lxk in the patch folder and install it.
6. Continue the installing steps
7. After all, run the patch file ( patch.exe ) point it to your proteus folder
8. Thats all, enjoy...
 楼主| 发表于 2010-4-27 01:42:15 | 显示全部楼层
 楼主| 发表于 2010-4-27 01:44:35 | 显示全部楼层
 楼主| 发表于 2010-4-27 01:46:02 | 显示全部楼层
GMT+8, 2025-12-30 07:36 , Processed in 0.024588 second(s), 5 queries , Gzip On, Redis On.
