查看: 1913|回复: 1
[招聘] NO.119-IC Verification Engineer(Beijing)
发表于 2010-4-21 16:28:54 | 显示全部楼层 |阅读模式
Responsibility:
- Instrumental in the development of infrastructure for the validation of architectures and the verification of hardware
- Additional duties include the development of directed and random hardware verification environments, and the application of those environments to SOC verification
- Debugging RTL simulations
- Hardware emulation
Qualification:
- Extensive Verilog/VHDL experience with SOC verification environments (Experience with VCS a plus.)
- Communications, ARM, AXI, Ethernet, USB, Video processing, display background
- Experience developing bus functional models, monitors, scoreboards, generators, functional coverage models
- Experience in using reference models to verify hardware
- Shell scripts and Perl expertise, create runsim, lsf, regression management scripts
- Experience with high level verification languages such as SystemC, SystemVerilog, OVM, VMM, Vera or Specman, as well as System C/ C / C++ programming background
- Able to understand verilog/VHDL RTL code, debug simulation errors, identify and fix RTL/Environment issues
- Experience in FPGA verification
- Excellent communication skills as detailed documentation of test plans and test matrixes
- At least 3 year experience in IC verification
- High degree of initiative and responsibility
- Team player, and easy to work with
- Fluent in English
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
发表于 2010-4-21 23:10:52 | 显示全部楼层
ddddddddddddddddddddddddd
GMT+8, 2025-12-24 02:56 , Processed in 0.019486 second(s), 5 queries , Gzip On, Redis On.
