查看: 4393|回复: 12
GNSS波束形成
发表于 2010-4-6 13:53:43 | 显示全部楼层 |阅读模式
这篇论文较好地分析了GNSS接收机的波束形成器结构
A gnss software receiver beamforming architecture.pdf
486.21 KB, 下载次数: 124 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-4-7 15:40:59 | 显示全部楼层
Re!顶一个!
发表于 2010-4-9 18:44:28 | 显示全部楼层
xie xie fen xiang
发表于 2010-4-16 15:47:52 | 显示全部楼层
thanks a lot
发表于 2010-4-20 12:05:11 | 显示全部楼层
学习一下!感谢分享!!
发表于 2011-5-11 14:08:13 | 显示全部楼层
Re!顶一个!
发表于 2011-11-22 17:23:52 | 显示全部楼层
kankanle,duoxiele
发表于 2012-1-15 13:05:32 | 显示全部楼层
下来看看
发表于 2013-7-14 00:24:42 | 显示全部楼层
ABSTRACT
Digital beamforming is an effective way to improve
gain in the direction of a transmitting GNSS satellite, and
to null in the direction of undesired signals such as
interference and multipath. However, the utilisation of
multiple antennas makes the architecture and signal
processing of GNSS receivers significantly different from
single-antenna receivers. This paper describes a method
of simplifying the architecture of multi-antenna GNSS
receivers. The authors propose an alternative
beamforming architecture utilising the maximum Signal
to Interference plus Noise Ratio (SINR) criterion. This
architecture can make the beamforming processing subsystem
a standalone module instead of being integrated
within the tracking loop. A multi-antenna GNSS receiver
was developed based on the Kai Borre single-antenna
GNSS software receiver. Simulation results demonstrate
that this architecture is effective in improving the Carrierto-
Noise power density ratio (C/No) of the received signal,
as well as in reducing the receiver tracking error.
发表于 2013-12-6 18:02:39 | 显示全部楼层
回复 1# budebushuai
   斤斤计较几家
GMT+8, 2025-10-17 03:45 , Processed in 0.041358 second(s), 8 queries , Gzip On, Redis On.
