查看: 3351|回复: 2
[求助] 将GDS文件导入ADS时出的错,请大家帮帮忙!谢谢!
发表于 2010-3-25 15:39:36 | 显示全部楼层 |阅读模式
Using layers file "E:/users/default/UWBlna_inductor1_prj/lay091202.lay".
Wed Mar 24 08:47:54 2010
Reading GDSII file "E:/users/default/UWBlna_inductor1_prj/UWBlna_inductor1.gds".
WARNING: Failed to create a design for the GDSII structure "UWBlna_inductor1" because the design "E:\users\default\UWBlna_inductor1_prj\networks\UWBlna_inductor1" is currently open.
The open design will be used for the import. To avoid this warning message in the future close all designs before performing an import.
WARNING: Found a structure reference (SREF) referenced within itself in the "UWBlna_inductor1" structure. This SREF will be ignored
ERROR: Invalid SREF element in 'UWBlna_inductor1' structure The corresponding GDSII element was ignored and will not appear in the design named "UWBlna_inductor1".
WARNING: Detected more than 1 top level structure (i.e. multiple GDSII structures
were found that are not referenced in other structures). The structure "uwblna_inductor1"
will be used as the top design.
Import Complete - 3 warnings, 1 error
发表于 2010-3-25 18:22:19 | 显示全部楼层
好像是两个design-kit不对应吧,或者一些定义不一致,所以有的文件没法导入
发表于 2010-3-28 01:10:10 | 显示全部楼层
牛人,能说的具体点吗?
GMT+8, 2025-12-26 13:41 , Processed in 0.027834 second(s), 8 queries , Gzip On, Redis On.
