module config_mux (pci_dat_out, ba0_size, ba1_size, bkend_dat,
pci_dat, pci_cbe_l, pci_addr, pci_rst_l,
abort_sig, pci_clk, com, cbe_reg_l,
idsel_reg, ba0, ba1, pci_irdy_l ,pci_ad);
output [31:0] pci_dat_out; // the pci output data bus
output [31:4] ba0_size; // The address space required for ba0
output [31:4] ba1_size; // The address space required for ba1
output [1:0] com; // The Mem - I/O enable bits of the command reg
output [31:0] ba0;
output [31:0] ba1;
input pci_irdy_l;
input [3:0] cbe_reg_l;
input idsel_reg;
input [31:0] bkend_dat; // back end data in
input [7:0] pci_addr;
input [31:0] pci_dat; // pci data
input [3:0] pci_cbe_l; // byte enables in
input pci_rst_l; // async reset
input abort_sig; // state machine is aborting set status
input pci_clk;
input [31:0] pci_ad;
reg [7:0] int_line; // r/w interupt line register
reg [31:0] pci_dat_out; // output data bus
reg [31:0] cfg_dat_out; // output data bus
reg [1:0] com; // The command register
reg stat11; // The status register bit for signaled target abort
reg stat_com_en;
reg int_line_en;
reg ba1_en;
reg ba0_en;
wire cfg_en;
reg cfg_out;
reg [31:0] ba0; // output data bus
reg [31:0] ba1;
parameter DEVICE_ID = 16'h0120; // User Defined
parameter VENDOR_ID = 16'h1022; // Set to AMD
`define fast 2'b00
`define medium 2'b01
`define slow 2'b10
parameter DEV_SEL = `slow; // medium devsel timing
always @ (posedge pci_clk or negedge pci_rst_l)
if (pci_rst_l == 1'b0)
begin
com <= 2'b00; // disable I/O and MEM space accesses.
stat11 <= 1'b0; // reset target abort status bit
end
else if (stat_com_en == 1'b1) begin
if (!pci_cbe_l[0]) // check to see if byte lane is enabled
com <= pci_dat[1:0];
else
com <= com;
if (!pci_cbe_l[3] && pci_dat[27]) // check to see if byte lane is enabled
stat11 <= 0; // write a 1 clears this bit
else
stat11 <= stat11;
end
else if (abort_sig == 1'b1) begin
stat11 <= 1'b1; // set target abort status bit
com <= com;
end
else begin
stat11 <= stat11;
com <= com;
end
parameter CLASS_CODE = 24'h058000; // Memory Controller
parameter REVISION_ID = 8'h01; // Rev. 01
parameter MISC_FUNCTIONS = 32'h00000000;
`define MEM_ON 1'b0
`define IO_ON 1'b1
`define ANYWHERE_IN_32 2'b00
`define BELOW_1M 2'b01
`define ANYWHERE_IN_64 2'b10
`define PREFETCH_ON 1'b1
`define PREFETCH_OFF 1'b0
`define ADDR_2G 28'h8000_000
`define ADDR_1G 28'hC000_000
`define ADDR_512M 28'hE000_000
`define ADDR_256M 28'hF000_000
`define ADDR_128M 28'hF800_000
`define ADDR_64M 28'hFC00_000
`define ADDR_32M 28'hFE00_000
`define ADDR_16M 28'hFF00_000
`define ADDR_8M 28'hFF80_000
`define ADDR_4M 28'hFFC0_000
`define ADDR_2M 28'hFFE0_000
`define ADDR_1M 28'hFFF0_000
`define ADDR_512K 28'hFFF8_000
`define ADDR_256K 28'hFFFC_000
`define ADDR_128K 28'hFFFE_000
`define ADDR_64K 28'hFFFF_000
`define ADDR_32K 28'hFFFF_800
`define ADDR_16K 28'hFFFF_C00
`define ADDR_8K 28'hFFFF_E00
`define ADDR_4K 28'hFFFF_F00
`define ADDR_2K 28'hFFFF_F80
`define ADDR_1K 28'hFFFF_FC0
`define ADDR_512 28'hFFFF_FE0
`define ADDR_256 28'hFFFF_FF0
`define ADDR_128 28'hFFFF_FF8
`define ADDR_64 28'hFFFF_FFC
`define ADDR_32 28'hFFFF_FFE
`define ADDR_16 28'hFFFF_FFF
parameter [31:0] BA0 = {`ADDR_16,`PREFETCH_OFF,`ANYWHERE_IN_32,`IO_ON};
assign ba0_size = BA0[31:4]; // Used to decode hit_ba0_l
/************ End Reg 10h Section *****************/
// reg 14h (Base Address 1) BA1 Using `defines from above
parameter [31:0] BA1 = {`ADDR_2K,`PREFETCH_OFF,`ANYWHERE_IN_32,`MEM_ON};
assign ba1_size = BA1[31:4]; // Used to decode hit_ba1_l
begin
if (pci_rst_l == 1'b0) begin
ba0 <= BA0;
ba1 <= BA1;
end
else if (ba0_en == 1'b1) begin
ba0[31:4] <= pci_ad[31:4]&BA0[31:4]; // write the base address during a config cycle
end
else if (ba1_en == 1'b1) begin
ba1[31:4] <= pci_ad[31:4]&BA1[31:4]; // write the base address during a config cycle
end
else begin
ba0 <= ba0;
ba1 <= ba1;
end
end
// reg 2Ch (SubsystemID/Subsystem VendorID)
parameter SUB_SYSTEM_ID = 16'h0120; // User Defined Could be anything
parameter SUB_VENDOR_ID = 16'h1022; // Set to AMD
// reg 3C (Max_Lat/Min_Gnt/Interrupt Pin/ Interupt Line)
// Interupt Pin is set to 1 corresponding to inta_l
parameter INT_PIN = 8'h01;
// The int_line reg is defined here
// The software will write to this register
// to set the system IRQ used for the interrupt
int_line = 8'h00;
end
else if (int_line_en && !pci_cbe_l[0] ) begin // check byte enables
int_line = pci_dat[7:0];
end
else begin
int_line = int_line;
end
`define write_04 (pci_addr[7:0] == 8'h04)
`define write_10 (pci_addr[7:0] == 8'h10)
`define write_14 (pci_addr[7:0] == 8'h14)
`define write_3C (pci_addr[7:0] == 8'h3C)
assign cfg_en = (cbe_reg_l == 4'b1011 && idsel_reg == 1'b1) ? 1'b1 : 1'b0;
always @ (cfg_en or pci_irdy_l or pci_addr[7:0])
begin
if (cfg_en && !pci_irdy_l) begin
if (`write_04) begin
stat_com_en <= #1 1;
ba0_en <= #1 0;
ba1_en <= #1 0;
int_line_en <= #1 0;
end
else if (`write_10) begin
ba0_en <= #1 1;
stat_com_en <= #1 0;
ba1_en <= #1 0;
end
else if (`write_14) begin
ba1_en <= #1 1;
ba0_en <= #1 0;
end
else if (`write_3C) begin
int_line_en <= #1 1;
ba0_en <= #1 0;
ba1_en <= #1 0;
end
else begin
ba0_en <= #1 0;
ba1_en <= #1 0;
end
end
else begin
ba0_en <= #1 0;
ba1_en <= #1 0;
end
end
begin
if (!pci_rst_l) begin
cfg_out <= #1 1'b0;
end
else if (cbe_reg_l == 4'b1010) begin
cfg_out <= #1 1'b1;
end
else begin
cfg_out <= #1 1'b0;
end
end
always @ (cfg_dat_out or bkend_dat or cfg_out)
begin
if (cfg_out) begin
pci_dat_out <= #1 cfg_dat_out;
end
else
begin
pci_dat_out <= #1 bkend_dat[31:0];
end
end
begin
cfg_dat_out <= #1 32'b0; // zero at reset
end
else begin
case (pci_addr [5:2])
4'b00_00: cfg_dat_out <= #1 {DEVICE_ID,VENDOR_ID};// reg 00h (DevID/VendorID)
4'b00_01: cfg_dat_out <= #1 {4'b0,stat11,DEV_SEL,9'b0,14'b0,com};//reg 04h (status/command)
4'b00_10: cfg_dat_out <= #1 {CLASS_CODE,REVISION_ID}; // reg 08h (Class/revision)
4'b00_11: cfg_dat_out <= #1 MISC_FUNCTIONS; // reg 0Ch (Misc Functions);
4'b01_00: cfg_dat_out <= #1 ba0; // reg 10h (Base Address 0);
4'b01_01: cfg_dat_out <= #1 ba1; // reg 14h (Base Address 1);
4'b10_11: cfg_dat_out <= #1 {SUB_SYSTEM_ID,SUB_VENDOR_ID}; // reg 2Ch (SubsystemID/Subsystem VendorID);
4'b11_11: cfg_dat_out <= #1 {16'b0,INT_PIN,int_line}; // reg 3C (Max_Lat/Min_Gnt/Interrupt Pin/ Interupt Line);
default: cfg_dat_out <= #1 32'b0; // unimplemented return 0's;
endcase
end
end
/************ End Output Mux Section ***************/
endmodule //of config_mux
对这个程序用modelsim仿真时,想要得DEVICE_ID,VENDOR_ID时只有低16位的数,不明白是怎么一回事.看看我的激励有问题吗??我对别的仿真都得到了结果...
谢谢, |
ISE激励文件
