发表于 2007-1-29 08:43:18
显示全部楼层
Preface3
A concerted effort is made to teach converter modeling. Fundamental topics covered include:
l Fundamentals of PWM converter analysis, including the principles of inductor volt-second balance and capacitor
charge balance, and the small-ripple approximation (Chapter 2).
l Converter modeling, including the use of the dc transformer model, to predict efficiency and losses (Chapter 3).
l Realization of switching elements using semiconductor devices. One-, two-, and four-quadrant switches. A brief
survey of power semiconductor devices (Chapter 4).
l An up-to-date treatment of switching losses and their origins. Diode stored charge, device capacitances, and
ringing waveforms (Chapter 4).
l Origin and steady-state analysis of the discontinuous conduction mode (Chapter 5).
l Converter topologies (Chapter 6).
l The use of averaging to model converter small-signal ac behavior. Averaged switch modeling (Chapter 7).
l Converter small-signal ac transfer functions, including the origins of resonances and right half-plane zeroes.
Control-to-output and line-to-output transfer functions, and output impedance (Chapter 8).
l A basic discussion of converter control systems, including objectives, the system block diagram, and the effect of
feedback on converter behavior (Chapter 9).
l Ac modeling of the discontinuous conduction mode. Quantitative behavior of DCM small-signal transfer functions
(Chapter 10).
l Current-programmed control. Oscillation for D > 0.5. Equivalent circuit modeling (Chapter 11).
l Basic magnetics, including inductor and transformer modeling, and loss mechanisms in high-frequency power
magnetics (Chapter 12).
l An understanding of what determines the size of power inductors and transformers. Power inductor and
transformer design issues (Chapters 13 and 14).
l Harmonics in power systems (Chapter 15).
l A modern viewpoint of rectifiers, including harmonics, power factor, and mitigation techniques in conventional
rectifiers, and operation of sophisticated low-harmonic rectifiers (Chapters 16-18).
l Analysis and modeling of low-harmonic rectifiers (Chapters 17-18).
l Resonant inverters and dc-dc converters: approximate analysis techniques, characteristics of basic converters, and load-dependent properties (Chapter 19).
l Zero voltage switching, zero current switching, and the zero-voltage-transition converter (Chapter 19).
l Resonant switch converters, including basic operation, efficiency and losses, and ac modeling (Chapter 20).
On teaching averaged converter modeling: I think that this is one of the important fundamentals of the
field, and hence we should put serious effort into teaching it. Although we in the academic community
may debate how to rigorously justify averaging, nonetheless it is easy to teach the students to average:
Just average all of the waveforms over one switching period. In particular, for the continuous conduction
mode, average the inductor voltages and capacitor currents over one switching period, ignoring the
ripple. That's all that is required, and I have found that students quickly and easily learn to average
waveforms. The results are completely general, they aren't limited to SPDT switches, and they can easily
be used to refine the model by inclusion of losses, dynamics, and control variations. To model dynamics,
it is also necessary to linearize the resulting equations. But derivation of small-signal models is nothing
new to the students --they have already seen this in their core electronics classes, as well as in numerous
math courses and perhaps also in energy conversion. It isn't necessary to teach full-blown state-space
averaging, but I have included an optional (with asterisk) section on this for the graduate students. I
personally prefer to initially skip Sections 7.4 and 7.5. After covering Chapters 8 and 9, I return to cover
Sections 7.4 and 7.5 before teaching Chapters 10 and 11. |
