楼主: bondultimate
Help for installing ASSURA 317 OA with IC610
发表于 2010-6-1 09:02:31 | 显示全部楼层
12445 files checked, 168 changed.
1 errors, 212 warnings occurred.
发表于 2010-7-4 14:47:27 | 显示全部楼层
fakee
发表于 2010-12-14 13:47:56 | 显示全部楼层
发表于 2011-2-12 11:36:15 | 显示全部楼层
thanks alot
发表于 2011-2-13 08:17:44 | 显示全部楼层
Also, even if Calibre patch is working. it won't run under Ubuntu. Check the OS compatabilities first before you install Van. otherwise it just a waste of time. it happen to me before.
发表于 2011-2-14 07:06:38 | 显示全部楼层
Is there a document file on how to install?
I didnt see a SETUP.SH file when extracting.
any helps?
发表于 2011-2-14 16:52:06 | 显示全部楼层
I need some help on install this software plz. when i tried to install it said you  don't have write permissions for install/tmp. i can't change the permission on /cdrom.
need some helps. thanks
发表于 2011-8-29 03:29:41 | 显示全部楼层
回复 27# truviet911
    把安装文件拷到自己的目录
发表于 2011-10-22 09:04:02 | 显示全部楼层
发表于 2011-10-25 14:15:22 | 显示全部楼层
我按照newsunny大大所提到的
去改檔案$ASSURAHOME/tools/bin/assura
問題來了....當我下指令:
uname -r 顯示==>2.6.18-194.el5
uname -v 顯示==>#1 SMP Tue Mar 16 21:52:39 EDT 2010
kennel version應該是: "2.6.18"
在修改了$ASSURAHOME/tools/bin/assura後還是開啟不了
出現下面的錯誤訊息:
[monkey@server proj]$ assura
ERROR: $OA_HOME is not set and the Cadence installation does not
seem to have a valid default OA installation under
/home/monkey/tool/eda/ASSURA317/share/oa
Check your OA installation (you may need to re-run
the post-install configure step for your Cadence tools), or set the
OA_HOME variable to point to a valid OA installation.
See the "OpenAccess Installation and Configuration Guide"
for more information.
assura:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsG        etOABinPath.
assura:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
assura:          See the "OpenAccess Installation and Configuration Guide" before
assura:          you complete the configuration step. This manual is included with
assura:          the Cadence product documentation.
跪求高手解答
GMT+8, 2025-9-13 04:31 , Processed in 0.025602 second(s), 3 queries , Gzip On, Redis On.
