楼主: bondultimate
Help for installing ASSURA 317 OA with IC610
 楼主| 发表于 2010-3-6 15:40:37 | 显示全部楼层
Hi Van,
I wanted to tell you the whole process online.
Please come online on yahoo.My yahoo ID is analogdesigner4@yahoo.co.in
You can find me online on weekends time is 8:00 AM GMT - 12:00 AM GMT. See you there.
Thanks
Farzad
发表于 2010-3-6 21:11:13 | 显示全部楼层
thank bondultimate very much
i will contact to you
you can hefp me install calibre 2009
发表于 2010-3-6 21:12:51 | 显示全部楼层
发表于 2010-3-9 10:28:42 | 显示全部楼层
[root@localhost vanduongbk]# assura
/bin/ls: error while loading shared libraries: librt.so.1: cannot open shared object file: No such file or directory
/bin/sh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
assura:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
assura:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
assura:          See the "OpenAccess Installation and Configuration Guide" before
assura:          you complete the configuration step. This manual is included with
assura:          the Cadence product documentation.
please hefp me
发表于 2010-3-18 11:32:30 | 显示全部楼层
ok thank you
i install it complete
发表于 2010-3-18 11:35:00 | 显示全部楼层
ok thank you
发表于 2010-3-18 11:36:27 | 显示全部楼层
ok thank you
发表于 2010-3-18 11:38:12 | 显示全部楼层
ok thank you
发表于 2010-4-9 22:31:37 | 显示全部楼层
Can you write a document about how to install assura 317 oa with IC610? I aslo download the assura 317 intalled file, but can't integrate it with IC610. Thank you very much!
发表于 2010-5-9 12:44:26 | 显示全部楼层
I find two other things should be done to run assura sucessfully.
First, you should define the Enviroment Variable "ASSURAHOME = your assura installed directory", and then you can see it in the layout editor menu. Note that it should be
"ASSURAHOME", not "ASSURA_HOME" or other.
Next, modify the script $ASSURAHOME/tools/bin/assura, find the definition of the  function "configKernel", and change all "2.4.19" to your linux kernel version. You can run "uname -a" to get your linux kernel version. I guess the assura was originally
installed in a "2.4.19" machine.
GMT+8, 2025-9-13 04:27 , Processed in 0.021089 second(s), 3 queries , Gzip On, Redis On.
