查看: 2781|回复: 4
Designing Analog Chips
发表于 2006-8-21 14:05:23 | 显示全部楼层 |阅读模式
Table of Contents
Analog World
1 Devices 1-1
Semiconductors 1-1
The Diode 1-5
The Bipolar Transistor 1-6
The Integrated Circuit 1-13
Integrated NPN Transistors 1-14
The Case of the Lateral PNP Transistor 1-22
CMOS Transistors 1-23
The Substrate PNP Transistor 1-27
Diodes 1-27
Zener Diodes 1-28
Resistors 1-29
Capacitors 1-32
Other Processes 1-33
CMOS vs. Bipolar 1-34
2 Simulation 2-1
What You Can Simulate 2-2
DC Analysis 2-2
AC Analysis 2-3
Transient Analysis 2-4
The Big Question of Variations 2-6
Models 2-8
The Diode Model 2-8
The Bipolar Transistor Model 2-10
The Model for the Lateral PNP Transistor 2-13
MOS Transistor Models 2-14
Resistor Models 2-16
Models for Capacitors 2-17
Pads and Pins 2-17
Just How Accurate is a Model? 2-18
3 Current Mirrors 3-1
4 The Royal Differential Pair 4-1
5 Current Sources 5-1
Bipolar 5-1
CMOS 5-7
The Ideal Current Source 5-7
6 Time Out: Analog Measures 6-1
dB 6-1
RMS 6-2
Noise 6-4
Fourier Analysis, Distortion 6-6
Frequency Compensation 6-9
7 Bandgap References 7-1
Low-Voltage Bandgap References 7-11
designinganalogchips.part2.rar
368.44 KB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-8-21 14:12:40 | 显示全部楼层
这是一本不错的书,很容易读的!
发表于 2006-8-21 19:47:44 | 显示全部楼层
又被你赚去很多钱。。。唉!!
发表于 2006-8-21 19:50:30 | 显示全部楼层
多是讲双极的,很少MOS。。
发表于 2010-4-24 15:47:30 | 显示全部楼层
好东西!谢谢!
GMT+8, 2025-12-19 22:22 , Processed in 0.025967 second(s), 6 queries , Gzip On, Redis On.
