查看: 3619|回复: 1
[求助] spectre RF pss sweep error
发表于 2010-1-22 11:05:49 | 显示全部楼层 |阅读模式
I am getting the following error during PSS sweep analysis:
Internal error found in spectre during sweep analysis`sweeppss'. Please run `getSpectreFiles' or send the netlist, thespectre log file, the behavioral model files, and any other informationthat can help identify the problem to support(at)cadence.com.
my spectre version is mmsim6.1. who  know what's the problem ? thank you all!
发表于 2016-4-18 15:39:52 | 显示全部楼层
回复 1# zhfhit
    I also encountered that problem .Have you solved it ?
GMT+8, 2025-12-25 21:28 , Processed in 0.017002 second(s), 7 queries , Gzip On, Redis On.
