查看: 7861|回复: 13
Sentaurus 软件安装问题
发表于 2010-1-15 15:41:35 | 显示全部楼层 |阅读模式
按照论坛上的安装方法安装之后,出现了以下问题
键入lmgrd后,出现
16:34:57 (snpslmd) Server started on localhost.localdomain for: SSS
16:34:57 (snpslmd)
16:34:57 (snpslmd) Licenses are case sensitive for TE_CATS
16:34:57 (snpslmd)
16:34:57 (lmgrd) snpslmd using TCP-port 55424
16:34:57 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
16:34:57 (snpslmd) ------------------------------------------------------------------
16:34:57 (snpslmd) Checking the integrity of the license file....
16:34:57 (snpslmd) Valid SSS feature found.
16:34:57 (snpslmd) The feature is needed to enable the other keys in your license file.
lisence程序应该是起来了吧?
[root@localhost ~]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version A-2008.09                           ***
***                        (1.4, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2009                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
16:35:01 (snpslmd) TCP_NODELAY NOT enabled
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (BD4C30CE542428ED00A4) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "SK_swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
License checkout failed: License server system does not support this feature.
Feature:       swb_all
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-18,147
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2008.09"
        * server name is "localhost.localdomain"
        * daemon is "snpslmd"
        * code is "BD4C30CE542428ED00A4"
        * expiry date is "31-dec-2019"
        * STROOT is "/usr/synopsys"
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/1"
        * user is "root"
[root@localhost ~]#
为什么总提示那个swb不对
那位高人帮我看看 到底出了什么问题?
发表于 2010-1-15 17:02:38 | 显示全部楼层
看看/etc/hosts 的最后一行,跟着IP地址后面的是否有localhost? 如果没有添加进去。这样的话应该就不会有问题了
发表于 2010-1-15 17:06:17 | 显示全部楼层
有时候可能需要先lmdown一下,然后再运行lmgrd
 楼主| 发表于 2010-1-16 09:35:51 | 显示全部楼层
自己顶一下,不要沉了
 楼主| 发表于 2010-1-16 10:06:03 | 显示全部楼层
2# loogwen
/etc/hosts 中的内容如下
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1  localhost.localdomain localhost
::1  localhost6.localdomain6 localhost6
哪里不对呢
发表于 2010-1-16 10:26:11 | 显示全部楼层
lisence程序应该是起来了吧?
License肯定没通过!
 楼主| 发表于 2010-1-16 10:42:52 | 显示全部楼层
6# s98006368
swb 那个feature 好像没授权,  不知道怎么办
发表于 2010-4-18 17:18:30 | 显示全部楼层
我搞了好久才搞定....
wo把license中的<host_name>方括号去掉,.bashrc中<host_name>方括号去掉
发表于 2010-10-23 20:20:22 | 显示全部楼层
回复 1# liuch23
    lllllllllllllllll
发表于 2010-10-23 20:28:18 | 显示全部楼层
回复 1# liuch23
    hhhhhhhhhhhh
GMT+8, 2025-12-18 16:54 , Processed in 0.023235 second(s), 6 queries , Gzip On, Redis On.
