查看: 12133|回复: 21
[求助] Sentaurus TCAD软件安装问题,跪求
发表于 2010-1-15 15:35:09 | 显示全部楼层 |阅读模式
按照论坛上的安装方法安装之后,出现了以下问题
键入lmgrd后,出现
16:34:57 (snpslmd) Server started on localhost.localdomain for: SSS
16:34:57 (snpslmd)
16:34:57 (snpslmd) Licenses are case sensitive for TE_CATS
16:34:57 (snpslmd)
16:34:57 (lmgrd) snpslmd using TCP-port 55424
16:34:57 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
16:34:57 (snpslmd) ------------------------------------------------------------------
16:34:57 (snpslmd) Checking the integrity of the license file....
16:34:57 (snpslmd) Valid SSS feature found.
16:34:57 (snpslmd) The feature is needed to enable the other keys in your license file.
lisence程序应该是起来了吧?
[root@localhost ~]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version A-2008.09                           ***
***                        (1.4, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2009                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
16:35:01 (snpslmd) TCP_NODELAY NOT enabled
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (BD4C30CE542428ED00A4) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "SK_swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
License checkout failed: License server system does not support this feature.
Feature:       swb_all
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-18,147
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2008.09"
        * server name is "localhost.localdomain"
        * daemon is "snpslmd"
        * code is "BD4C30CE542428ED00A4"
        * expiry date is "31-dec-2019"
        * STROOT is "/usr/synopsys"
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/1"
        * user is "root"
[root@localhost ~]#
为什么总提示那个swb不对
那位高人帮我看看 到底出了什么问题?
发表于 2010-4-18 17:21:08 | 显示全部楼层
路径设置、<host_name>的方括号到底要不要、lmhostid等等,多试试多想想
发表于 2010-5-6 13:07:57 | 显示全部楼层
I got the same problem.
Can some one give a help
发表于 2010-5-8 00:32:47 | 显示全部楼层
I fjust find that I have done a mistake during the installation.
Now, the program is working and all thing is right.
I think, you have done the same error than me. So read and follow carefully the installation procedure
(I forgot two lines in the src file) and all will be fine.
发表于 2010-6-9 22:01:40 | 显示全部楼层
我也有好多问题没有解决,打车同问啊
发表于 2010-8-31 19:40:19 | 显示全部楼层
我也遇到同样的问题,请问4楼到底是怎么解决的
发表于 2010-9-4 18:01:39 | 显示全部楼层
同问???????????????????????????
发表于 2010-9-4 18:36:11 | 显示全部楼层
how~?
发表于 2010-10-16 19:06:38 | 显示全部楼层
应该是license有问题吧,我也碰到过,装了好几次,最后已不知怎么就好了。
发表于 2010-10-23 20:04:11 | 显示全部楼层
回复 1# liuch23
    hhhhhhhhhhhhhhhhhhh
GMT+8, 2025-9-21 10:03 , Processed in 0.019779 second(s), 7 queries , Gzip On, Redis On.
