查看: 5280|回复: 13
有没有vista下能用的Leonardospectrum?
发表于 2010-1-15 01:34:12 | 显示全部楼层 |阅读模式
安装Leonardospectrum后无法进入,提示说Leonardospectrum stop working, closing the program.是否与vista环境有关?
发表于 2010-5-5 10:36:46 | 显示全部楼层
我在win7下安装LeonardoSpectrum2005也不能用提示:mem heak error什么的错误信息
发表于 2011-1-13 22:31:46 | 显示全部楼层
啊……,白下了?
发表于 2011-10-2 08:25:10 | 显示全部楼层
好东西,正需要呢
发表于 2011-10-2 08:30:35 | 显示全部楼层
顶一个
发表于 2011-10-2 08:33:05 | 显示全部楼层
不知道是不是可以在win7下运行
发表于 2011-10-2 08:34:31 | 显示全部楼层
2001版本的不行
发表于 2012-10-2 06:17:18 | 显示全部楼层
实测2001 win7 64位无法使用。。
发表于 2016-3-13 15:42:34 | 显示全部楼层
感觉坛子上所有的leonard Spectrum在xp 32位下都无法安装
发表于 2024-10-7 20:06:32 | 显示全部楼层
For those using old leonardo and having this problem, it's because SmarHeap DLL had problems with multi-cores or multi cpus in the  system and in order to fix this just needed to upgrade those files Sh33w32.dll or Shw32.dll from 3.xx.xx into a recent version may be 10.xx or 11.xx version.
Those files are present in new version of Leonardo or Precision 32bits or other Mentor Programs for 32bits
Just copy this files Sh33w32.dll or Shw32.dll (version 10 or 11) and overwrite renaming it accordingly as it's named inside your program folder.
Leonardo can be installed from win 2k up to win 10 without any problem (didn't tested in win 11) but the only problem is the DLL that will treat threads and multi core and also if you can use a generic compiler for your IC in your modern windows or if will need to make an older compiler  to work in modern windows allowing 32/16bits program to work again !
Widnows 10 has a package to enable and allow execution of 16 bits program.
GMT+8, 2025-9-18 04:14 , Processed in 0.020774 second(s), 5 queries , Gzip On, Redis On.
