查看: 8401|回复: 8
CADENCE Orcad 16.3
发表于 2010-1-9 09:52:58 | 显示全部楼层 |阅读模式
CADENCE Orcad 16.3
Cadence SPB / OrCAD 16.30.000 (2009) | 1.76 Gb
CadenceSPB / OrCAD 16.30.000 is a comprehensive package of design ofelectronic circuits, analog and digital simulation, IC design ofprogrammable logic and custom circuits, as well as the development andpreparation for the production of printed circuit boards.
Thisrelease combines previously unreleased separate products from Cadence -Allegro SPB and OrCAD. When you install you must install one of theCadence SPB 16.3 ticks or Cadence OrCAD 16.3. Package OrCAD is a subsetof SPB. So if you want to set the maximum option - select the SPB anddo not choose OrCAD. Choice of two options will not add additionalprograms or Fitch.
Installing Cadence SPB / Orcad 16.3
1. Install the license server
2. Overwrite file cdslmd.exe in the installation folder of the license manager on the tablet attached to the
3.Create an environment variable with the value CDS_LIC_FILE this_host @5280. this_host replaced with the name of your machine (Mycomputer-> properties-> advanced-> enviromnent variables)
4. Edit the first line in the file license163.lic - replace this_host to the real name of your computer
5. Run LicenseServerConfiguration.exe folder license manager (LicenseManager)
6. In the Select license, select the edited file license163.lic
7. Click Next
8. In the Port number edit check the value 5280
9. In the editing window Host Name check your machine's hostname (computer name)
10. Click Next
11. Click Next again
12. Click Finish
13. Reboot
14. Set Cadence SPB / OrCAD 16.3
15. Copy the files from a folder ... Aspirinpatch in the installation directory
16. Start RunMe!. Bat
17. Wait
18. Wait a little
19. Enjoy the Cadence SPB / OrCAD 16.3
System requirements:
Operatingsystem: Windows 2008 Server, Windows 2003 Server, all Service Packs(only 32-bit); Windows XP Professional; Windows Vista (32 and 64 bit)except Home Basic.
Processor: Intel IA-32 compatible (including Intel P4 EMT and AMD OpteronTM); 1.2 GHz minimum, recommended 2.4 GHz or more.
Memory: At least 1 GB of physical RAM, 2 GB recommended
Virtual memory: at least twice the available physical memory.
Disk space: minimum of 10 GB, 50 GB recommended
Display: 1024x768 @ 64000 colors recommended 1280x1024 @ 32-bit color
Cadence SPB / OrCAD 16.30.000 (Allegro SPB)
Year: 2009
Version: 16.30.000
Developer: Cadence
Platform: Windows
Compatibility with Vista: Yes
Language: English
Tabletka: Present
All links are interchangeable
http://rapidshare.com/files/325833609/Cadence.SPB.16.3.part01.rar
http://rapidshare.com/files/325838777/Cadence.SPB.16.3.part02.rar
http://rapidshare.com/files/325838793/Cadence.SPB.16.3.part03.rar
http://rapidshare.com/files/325841349/Cadence.SPB.16.3.part04.rar
http://rapidshare.com/files/325838482/Cadence.SPB.16.3.part05.rar
http://rapidshare.com/files/325847705/Cadence.SPB.16.3.part06.rar
http://rapidshare.com/files/325859621/Cadence.SPB.16.3.part07.rar
http://rapidshare.com/files/325863785/Cadence.SPB.16.3.part08.rar
http://rapidshare.com/files/325859609/Cadence.SPB.16.3.part09.rar
http://rapidshare.com/files/325860030/Cadence.SPB.16.3.part10.rar
http://rapidshare.com/files/326072778/Cadence.SPB.16.3.part11.rar
http://rapidshare.com/files/325867613/Cadence.SPB.16.3.part12.rar
http://rapidshare.com/files/325870506/Cadence.SPB.16.3.part13.rar
http://rapidshare.com/files/326073008/Cadence.SPB.16.3.part14.rar
http://rapidshare.com/files/326072691/Cadence.SPB.16.3.part15.rar
http://rapidshare.com/files/326072626/Cadence.SPB.16.3.part16.rar
http://rapidshare.com/files/326071941/Cadence.SPB.16.3.part17.rar
http://rapidshare.com/files/326059790/Cadence.SPB.16.3.part18.rar
Mirror:
Download (Hotfile)
http://hotfile.com/dl/21798889/88e40f4/Cadence.SPB.16.3.part01.rar.html
http://hotfile.com/dl/21798890/287b21f/Cadence.SPB.16.3.part02.rar.html
http://hotfile.com/dl/21798893/2167441/Cadence.SPB.16.3.part03.rar.html
http://hotfile.com/dl/21798888/0fc991d/Cadence.SPB.16.3.part04.rar.html
http://hotfile.com/dl/21798895/e9f2225/Cadence.SPB.16.3.part05.rar.html
http://hotfile.com/dl/21798896/34e1a0d/Cadence.SPB.16.3.part06.rar.html
http://hotfile.com/dl/21798894/08a7bc7/Cadence.SPB.16.3.part07.rar.html
http://hotfile.com/dl/21798897/1f285c7/Cadence.SPB.16.3.part08.rar.html
http://hotfile.com/dl/21798891/2019683/Cadence.SPB.16.3.part09.rar.html
http://hotfile.com/dl/21798892/519c979/Cadence.SPB.16.3.part10.rar.html
http://hotfile.com/dl/21798975/02f9f76/Cadence.SPB.16.3.part11.rar.html
http://hotfile.com/dl/21798982/2c530cb/Cadence.SPB.16.3.part12.rar.html
http://hotfile.com/dl/21798991/9e26fcc/Cadence.SPB.16.3.part13.rar.html
http://hotfile.com/dl/21798993/344a522/Cadence.SPB.16.3.part14.rar.html
http://hotfile.com/dl/21798997/24ea4a7/Cadence.SPB.16.3.part15.rar.html
http://hotfile.com/dl/21798999/148c514/Cadence.SPB.16.3.part16.rar.html
http://hotfile.com/dl/21799001/b95ec20/Cadence.SPB.16.3.part17.rar.html
http://hotfile.com/dl/21799003/5af693d/Cadence.SPB.16.3.part18.rar.html
Mirror:
Download (Uploading)
http://uploading.com/files/f8m9m5ed/Cadence.SPB.16.3.part01.rar/
http://uploading.com/files/7eb88a7m/Cadence.SPB.16.3.part02.rar/
http://uploading.com/files/6bbmaaa7/Cadence.SPB.16.3.part03.rar/
http://uploading.com/files/2c8991c3/Cadence.SPB.16.3.part04.rar/
http://uploading.com/files/1649c4ea/Cadence.SPB.16.3.part05.rar/
http://uploading.com/files/m3d3b3ff/Cadence.SPB.16.3.part06.rar/
http://uploading.com/files/3d5ef476/Cadence.SPB.16.3.part07.rar/
http://uploading.com/files/c9a1d986/Cadence.SPB.16.3.part08.rar/
http://uploading.com/files/2ea12d4d/Cadence.SPB.16.3.part09.rar/
http://uploading.com/files/5949f994/Cadence.SPB.16.3.part10.rar/
http://uploading.com/files/f2dc5ffc/Cadence.SPB.16.3.part11.rar/
http://uploading.com/files/65511d4m/Cadence.SPB.16.3.part12.rar/
http://uploading.com/files/8c28ecbe/Cadence.SPB.16.3.part13.rar/
http://uploading.com/files/5d2b619f/Cadence.SPB.16.3.part14.rar/
http://uploading.com/files/2decdf6f/Cadence.SPB.16.3.part15.rar/
http://uploading.com/files/3ddac5a7/Cadence.SPB.16.3.part16.rar/
http://uploading.com/files/8d688ecm/Cadence.SPB.16.3.part17.rar/
http://uploading.com/files/d897276a/Cadence.SPB.16.3.part18.rar/
  Disk 1
http://rapidshare.com/files/74179493/co16sh_d1.part1.rar
http://rapidshare.com/files/74183324/co16sh_d1.part2.rar
http://rapidshare.com/files/74186997/co16sh_d1.part3.rar
http://rapidshare.com/files/74190882/co16sh_d1.part4.rar
http://rapidshare.com/files/74195434/co16sh_d1.part5.rar
http://rapidshare.com/files/74199453/co16sh_d1.part6.rar
http://rapidshare.com/files/74203823/co16sh_d1.part7.rar
http://rapidshare.com/files/74205613/co16sh_d1.part8.rar
  Disk 2
http://rapidshare.com/files/74210221/co16sh_d2.part1.rar
http://rapidshare.com/files/74223452/co16sh_d2.part2.rar
http://rapidshare.com/files/74231750/co16sh_d2.part3.rar
http://rapidshare.com/files/74241721/co16sh_d2.part4.rar
http://rapidshare.com/files/74252264/co16sh_d2.part5.rar
http://rapidshare.com/files/74256349/co16sh_d2.part6.rar
pass: ru-board
torrent alternative is avaliable on:
  http://www.btmon.com/Other/Unsorted/Cadence.OrCad.v16.0-SHooTERS.torrent.html
ftp links
Cadence.Allegro.PCB.Design.v16.2 ftp direct download with 3 part
ftp://162.105.76.250/Cadence.Allegro.PCB.Design.v16.2-SHooTERS/Cadence.Allegro.PCB.Design.v16.2.cd1.iso
ftp://162.105.76.250/Cadence.Allegro.PCB.Design.v16.2-SHooTERS/Cadence.Allegro.PCB.Design.v16.2.cd2.iso
ftp://162.105.76.250/Cadence.Allegro.PCB.Design.v16.2-SHooTERS/Cadence.Allegro.PCB.Design.v16.2.cd3.iso
发表于 2010-1-9 23:03:00 | 显示全部楼层
THANKS
发表于 2010-1-21 02:38:27 | 显示全部楼层
Very goo, thanks.
发表于 2010-4-25 14:35:03 | 显示全部楼层
thanks
发表于 2010-4-25 15:14:20 | 显示全部楼层
thanks,
发表于 2010-7-22 09:57:00 | 显示全部楼层
很好的东西 找了很长时间了 谢谢!
发表于 2010-8-4 20:54:37 | 显示全部楼层
不错!!!!!!!!!!
发表于 2010-8-23 18:48:33 | 显示全部楼层
电驴上的版本太暴力破解了。
发表于 2010-11-12 03:38:32 | 显示全部楼层
GMT+8, 2025-12-29 13:37 , Processed in 0.028683 second(s), 8 queries , Gzip On, Redis On.
