查看: 12272|回复: 55
ebook:switching power supply design Ed2 author:abrham I. pressman part2
发表于 2006-8-16 11:41:37 | 显示全部楼层 |阅读模式
part2
[ 本帖最后由 adan0306 于 2006-8-16 11:44 编辑 ]
Switch Power Supply Design.part02.rar
1.89 MB, 下载次数: 253 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-21 11:28:24 | 显示全部楼层
帮了我很大的忙,太感谢了~
发表于 2006-11-21 11:33:29 | 显示全部楼层
xiaxia
发表于 2006-11-21 11:35:51 | 显示全部楼层
xiaixia
发表于 2006-11-21 13:15:29 | 显示全部楼层
Thanks
发表于 2006-11-30 09:54:54 | 显示全部楼层
good.....lah
发表于 2006-12-19 09:08:24 | 显示全部楼层
评价!!!
If you're an avid electronics enthusiast, you've more than likely had to build some power supplies. The days of building simple linear supplies are over. If you need various voltages that are carefully controlled and/or just want to build efficient supplies, you need to build a switchmode power supply. This handbook will take you through the major topologies, explaining them all in detail, along with the necessary math to choose the proper components, and the theory of how it's done - and how to choose the proper topology in the first place. The book is well-written and stuffed full of very useful information. Power Factor Correction is also covered, with examples, chips, and theory to build PFC circuits, along with transformer design and theory as well. This book is a great book to buy with "Switchmode Power Supply Handbook", by Keith Billings. Keith's book presents additional information and transformer design mock-ups, along with additional ways to calculate and pick components. Used together, you have the information you need to build a working switching supply with a minimum of hassle. Of course, this assumes that you're already famaliar with electronics and magnetism, and have a good working knowledge of algebra and basic trig. These books are not meant for beginners by any means. I am one happy customer to have found such a good reference for an art that seems to only be known by a few anymore, and other reference materials do not even begin to go into the depth that this book does.
The only shortcoming is that Pulse Width Modulation power supply chips are not covered much, but this book cannot be expected to keep up with the latest PWM chips used in switchmode supplies. This problem is easily resolved by going to National Semiconductor's website and getting current datasheets on PWM chips for standalone, voltage-controlled or current-mode designs, of which they have many. Motorola also has reference materials available on PWM offerings that they carry.
发表于 2006-12-20 14:39:41 | 显示全部楼层
第1部分 拓扑分析
第1章 基本开关型调整器——buck、boost及反相型拓扑
1.1 简介
1.2 线性调整器——开关调整器的原型
1.2.1 基本工作原理及优缺点
1.2.2 线性调整器的缺点
1.2.3 串接晶体管的功率损耗
1.2.4 线性调整器的效率与输出电压的关系
1.2.5 串接PNP型晶体管的低压差线性调整器
1.3 buck开关型调整器拓扑
1.3.1 基本工作原理
1.3.2 buck调整器的主要电流波形
1.3.3 buck调整器的效率(忽略交流开关损耗)
1.3.4 buck调整器的效率(考虑交流开关损耗)
1.3.5 buck调整器的理想开关频率
1.3.6 参数设计——输出滤波电感的选择
1.3.7 参数设计——输出滤波电容的选择
1.3.8 有直流隔离调整输出的buck调整器的电压调节
1.4 boost开关调整器拓扑
1.4.1 基本原理
发表于 2006-12-24 22:48:32 | 显示全部楼层
下载不易啊。。。
发表于 2006-12-25 09:37:32 | 显示全部楼层
这个版本好像扫描质量一般 。
GMT+8, 2025-12-22 22:45 , Processed in 0.709115 second(s), 7 queries , Gzip On, Redis On.
