楼主: socrates77
dc2004 for linux安装包+license(附安装说明)
发表于 2014-3-20 21:11:01 | 显示全部楼层
这。。。。
发表于 2014-8-8 22:54:12 | 显示全部楼层
发表于 2014-8-8 23:10:15 | 显示全部楼层
发表于 2014-8-8 23:13:12 | 显示全部楼层
发表于 2014-8-8 23:19:37 | 显示全部楼层
发表于 2014-8-9 10:00:23 | 显示全部楼层
Physical Compiler
Physical Compiler®, the cornerstone of Synopsys’ physical synthesis solution and a key component of Synopsys’ Galaxy? Design Platform, enables register-transfer level (RTL) designers to deliver the highest-performance circuits in the shortest time. By unifying synthesis and placement, Physical
Compiler offers designers predictable timing closure from RTL to placed-gates for their most complex designs. Proven interfaces to third-party routers allow it to easily plug into an existing design flow.
Built upon the industry-standard Design Compiler®, Physical Compiler works seamlessly with Synopsys’ floor planning, power, datapath, test, routing, and DesignWare® solutions. Physical Compiler has been widely adopted by the design community with over a thousand tapeouts attributed to it. Physical Compiler enables customers to meet their time to market requirements with significant performance and productivity gains. All major ASIC vendors have design kit support for Physical Compiler and are using placement handoff to quickly close timing on their most complex designs.
Key benefits:
1 Delivers best QoR in terms of timing, power, area, and routability
2 Easy to adopt–Similar TCL environment to that of Design Compiler®, with a rich super set of powerful
commands and easy-to use graphical user interface (GUI) to get up and running quickly, and get the job done
3 Ensures consistent timing, constraints and library throughout Synopsys tools
4 Leverages customer investment
5 Plug-and-play solution for third-party place-and-route flows—industry standard format interfaces ensure smooth adoption
6 Comprehensive ASIC vendor support—users have the flexibility to choose between ASIC vendors and still maintain control over their design QoR and CAD tools
7 Fast and accurate implementation feasibility analysis –built-in register transfer level (RTL) Performance Prototyping (RPP) and quick placement mode help save time when exploring the effect of physical implementation on RTL architectural options during early stages of the design
8 Very fast runtimes for large (1M to 2M instances) flat chip designs with distributed physical synthesis (DPS)
9 Direct Milkyway? integration and RC model support enables a consistent and convergent flow with Astro for faster time to results
10 Global router integration for better timing predictability on congested designs (required PC Expert option)
11 Fast multi-Vth flow with Power Compiler for leakage optimization
12 Opteron 32/64 bit availability starting with v2003.12 for faster runtimes
发表于 2014-8-9 10:00:58 | 显示全部楼层
Product List
ACE, BSD Compiler ,Behavioral Compiler ,CoCentric SystemC Compiler ,
DFT Compiler ,Design Compiler, Design Vision, DesignWare Developer ,
DesignWare Foundation ,External Interfaces, FloorPlan Manager, HDL Compiler ,
Library Compiler ,Module Compiler ,Physical Compiler ,Power Compiler,
Synthesis ,
发表于 2014-9-15 14:49:26 | 显示全部楼层
顶一个
发表于 2014-9-16 15:27:50 | 显示全部楼层
哎,也不知道能不能用。。。
发表于 2016-5-21 13:32:58 | 显示全部楼层
多谢~
GMT+8, 2025-12-25 02:30 , Processed in 0.019630 second(s), 3 queries , Gzip On, Redis On.
