查看: 10595|回复: 18
[原创] dc-dc swithi线路高频负载分析(beat frequency)
发表于 2009-12-15 15:53:59 | 显示全部楼层 |阅读模式
Abstract:  Under  high-frequency  repetitive  load  transients,
multiphase voltage  regulators  (VRs)  suffer  from  beat-frequency
oscillations  of  the  phase  currents. To  investigate  this  issue,  this
paper  develops  a  methodology  based  on  the  multifrequency
model   with   describing   functions.   The   influences   from   the
interleaving  operation  are identified.  After  that,  the  analysis  is
extended  to  studying  of  the  higher-order  beat-frequency  issue.
Then,  a  solution  by  applying  coupled  inductors  is  proposed.
Experimental    and    simulation    results    are    presented    as
verification.*
abbr_87005eddd7737425124ca92f7ceec584.pdf
1.58 MB, 下载次数: 72 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-12-15 15:55:59 | 显示全部楼层
主要针对多phase 的buck线路分析
发表于 2009-12-16 18:19:20 | 显示全部楼层
英文的有点吃力
发表于 2009-12-16 19:01:13 | 显示全部楼层
不錯
发表于 2009-12-18 22:25:32 | 显示全部楼层
thanks~~
发表于 2009-12-29 23:26:00 | 显示全部楼层
ding
qilai
1# lenchol_jia
发表于 2009-12-29 23:28:47 | 显示全部楼层
7# zxfeng001
发表于 2010-1-1 20:41:46 | 显示全部楼层
good good
 楼主| 发表于 2010-1-15 09:58:02 | 显示全部楼层
tks!!!
发表于 2010-1-15 12:18:42 | 显示全部楼层
xiexie ..............................................
GMT+8, 2025-12-28 12:52 , Processed in 0.107956 second(s), 5 queries , Gzip On, Redis On.
