查看: 6042|回复: 20
CMOS Continuous-Time Multipliers_A Tutorial(Professor Sanchez(IEEE Fellow))
发表于 2006-8-8 12:14:14 | 显示全部楼层 |阅读模式
CMOS Continuous-Time Multipliers_A Tutorial.pdf
414.13 KB, 下载次数: 142 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-10 19:17:23 | 显示全部楼层
是fellow的我就看!
发表于 2006-11-11 08:05:44 | 显示全部楼层
good, thanks
发表于 2006-11-11 08:06:16 | 显示全部楼层
the papar is the calssic
发表于 2006-11-11 09:01:50 | 显示全部楼层
classic!!1
发表于 2006-11-11 09:03:27 | 显示全部楼层
good paper
发表于 2007-2-6 18:30:32 | 显示全部楼层
推荐!!!
发表于 2007-2-6 18:31:48 | 显示全部楼层
Abstract
Abstract—Real-time analog multiplication of two signals is one
of the most important operations in analog signal processing. The
multiplier is used not only as a computational building block but
also as a programming element in systems such as filters, neural
networks, and as mixers and modulators in a communication
system. Although high performance bipolar junction transistor
multipliers have been available for some time, the CMOS multiplier
implementation is still a challenging subject especially
for low-voltage and low-power circuit design. Despite the large
number of papers proposing new MOS multiplier structures,
they can be roughly grouped into a few categories. This tutorial
provides a complete survey of CMOS multipliers, presents a
unified generation of multiplier architectures, and proposes the
most recommended MOS multiplier structure. This tutorial could
serve as a starting reference point (and metric) for comparison
of new CMOS multiplier circuit configurations. An illustrative
CMOS chip prototype verifying theoretical results is presented.
Index Terms—CMOS multipliers, low noise design, low voltage
circuits, multipliers.
发表于 2007-2-6 18:33:35 | 显示全部楼层
Gunhee Han and Edgar S´anchez-Sinencio, Fellow, IEEE
IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS—II: ANALOG AND DIGITAL SIGNAL PROCESSING, VOL. 45, NO. 12, DECEMBER 1998
发表于 2007-2-6 18:34:52 | 显示全部楼层
CONCLUSION
CONCLUSION
Although a large number of transconductance multipliers
are reported in the literature, they fall into eight categories
described in this tutorial and are summarized in Table I.
Several multiplier architectures do not have any clear advantage
over others. As the current trend of circuit design is
low voltage and low power, the circuit shown in Fig. 7(c)
seems to be one of the most attractive low-voltage and highperformance
MOS multiplier structures. A BiCMOS version
that uses BJT instead of the source follower will improve
its performance. Several design considerations of the circuit
Fig. 7(c) were provided.
A reader should be aware that this comparison might not
hold for all cases. The choice of circuit topology is completely
dependent on design specifications.
GMT+8, 2025-12-25 17:41 , Processed in 0.020798 second(s), 5 queries , Gzip On, Redis On.
